Results 1 to 4 of 4
Thread: Is there any special 'pen' to use on touchscreens?
    Apr 2002
    socal
    I was just wondering if there is anykind of special pens such as the ones used on the palm pilot and pocket pc's. Reason is sometimes I wanna use the onscreen keyboard and I would think my fingers are too big and would hit 2 or 3 keys at once.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    If you want one it's called a stylus.
    http://www.styluscentral.com/
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    sometimes I use a pen. Just make sure the tip is not sharp so that you dont scratch the screen.
    Mine needs to be updated.
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    A stylus only works for touch resistive touchscreens. If your touch screen is heat sensitive, your out of luck. You'll probably never bump into a heat sensitive t/s for a carputer
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
