Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: Steering wheel remote controller USB interface - CarPC JoyCon EX
  1. #11
    Low Bitrate Challenged's Avatar
    Jan 2010
    Thanks, just ordered one; can't wait to try it out.
  2. #12
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    Quote Originally Posted by Challenged View Post
    where do you order from?
  3. #13
    May 2009
    It is on ebay.com
  4. #14
    Jan 2010
    Just search for joycon ex on ebay. What he said ^
  5. #15
    Nov 2006
    Mentor, OHIO
    thanks,
    also this will work with most any car right? i have a 2008 Civic Si and i just want to make sure before i buy
  6. #16
    Aug 2007
    Can this updated controller interface also allow for the signals to pass to the default car operations?
    E.g. when I press the vol up botton, pass the signal both to my pc and the car?
  7. #17
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by TemplarKnight View Post
    Now THAT ^^^^ would be great!!! I would buy two of them now if they did that (one to replace the one I already have).
  8. #18
    May 2009
    CarPC JoyCon EX support resistance-output steering wheel remote controls.
    These days most of car has resistance-output remote controls.
    But to make it sure, reference owner manual or repair manual of your car to check if it is resistance-output or not.
    Basically remote controls can not be connected both to CarPC JoyCon EX and car audio or other car devices, but it depends on the circuit of the car audio and car device.
    And one way to use one remote controls both for CarPC and other car device is to use two way switch for selecting CarPC and other car device.
  9. #19
    Nov 2006
    Mentor, OHIO
    couldn't you still have the old way setup and just tap into the wires with this?
  10. #20
    Dec 2007
    Danville, CA
    Quote Originally Posted by dhantiflag View Post
    With the old JoyCon you can't tap. You have to cut it, I think that if you add any wire to another, that in itself alters the overall resistence. I don't know, I'm guessing here.
    So for those like me who kept the head unit this is a bummer. If I could just tap, I could use the volume button to send a volume signal to the headunit and something else (say next track or whatever) to the computer...Actually you'd have to be carefull there, because you'd have to know what the car was doing...maybe that could work for track buttons, which are unused when the OEM Radio is in AUX mode.
    I'm guessing for that to work JoyCon would have to repeat/emulate whatever resistence it reads on another end, and have an output wire for us to reconnect the stock steering wheel buttons.
  1. Tutorial - Steering Wheel Controls
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 10-19-2010, 01:03 AM
  2. Replies: 0
    Last Post: 03-02-2010, 05:07 PM
  3. How Can I Build a Steering Wheel Control Interface
    By electro in forum Input Devices
    Last Post: 10-01-2008, 03:34 AM
  4. Steering Wheel Remote Control
    By drdave in forum Car Audio
    Last Post: 02-21-2008, 10:48 PM
  5. Steering Wheel Volume control interface
    By wizbangstokes in forum Input Devices
    Last Post: 10-23-2007, 11:36 PM
Tags for this Thread
