Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 66
Like Tree1Likes
Thread: Steering wheel remote controller USB interface - CarPC JoyCon EX
  1. #31
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    I think it cannot be used in Chrysler/Jeep/Dodge cars. In my 1999 Jeep Grand Cherokee, the commands from the steering wheel to the factory radio are sent through the PCI BUS. The controls on steering wheel are resistive type, but are routed to the PCM (Powertrain Control Module) that converts it to PCI BUS. The only way, unless someone knows ho to convert PCI bus msg in resistive, is to connect the JoyCon directly to the input to PCM, but it is very dangerous. You must to splice the wires on PCM or remove the airbag. Any ideas ?
    It's a Jeep thing...you wouldn't understand !--------------------------------------------
  2. #32
    Low Bitrate Challenged's Avatar
    Jan 2010
    According to their website, the 1999 Jeep Grand Cherokee works with the SWI-PS from PAC Audio. Here's the post earlier in this thread where I discuss the fact that it allowed me to use the Joycon on my 2010 Challenger. Steering wheel remote controller USB interface - CarPC JoyCon EX Here's the info from PAC Audio on the SWI-PS: http://www.pac-audio.com/productDeta...&CategoryID=29
    And here's my original post discussing the SWI-PS in my install thread: 2010 Dodge Challenger install
  3. #33
    Nov 2004
    Italy
    Hi Challenged...thank you! This mean that I can plug directly the Pac-Audio SWI-PS to the wire from the PCI Bus and connect Joycon input to the Jack in output to the Pac-Audio SWI-PS ? That's all ?
  4. #34
    Jan 2010
    I'm not positive which wire you're going to need to hook the SWI-PS up to on a Grand Cherokee, but that's the idea. The SWI-PS decodes the vehicle specific network data and converts it to resistance output. My install was a little different because I plugged the SWI-PS into another PAC-Audio device that decoded the factory amplifier controls, so the wiring technique is going to be a little different on your car I guess.
  5. #35
    Nov 2004
    Italy
    Quote Originally Posted by Challenged View Post
    Just ordered one, hope it works! I'll let you know! Grazie!
  6. #36
    Dec 2007
    MI-USA
    Is it possible to only buy the software? I already have the original CarPC Joycon, but I could really use the support of multimedia keys for my set up!
    EDIT: Sorry, I just realized the files for both XP and 7 are in the first post. Can't wait to try this out this afternoon, I love your product.
  7. #37
    May 2009
    Sorry but Multimedia key can be supported only by hardware. Original CarPC JoyCon can not support multimedia key.
    Only CarPC JoyCon EX supports Multimedia key by hardware.
    And the software JoyCon Explorer is free.
    You can always download the latest version at this link
    http://rcjoycon.com/default/menu_2.php?menu=2
  8. #38
    Mar 2010
    St. Louis MO
    Question....
    I have a chevy HHr. I purchased the Axxess GMOS-LAN-04 adapter and cannot figure out which wires I would use to wire it up to the Joycon Ex? I was hoping out of the bunch of wires one would have this info. I do see one for the Volume Level based on my speed, but I don't think that would be it?
    Any suggestions?
    Thanks,
    Rog
  9. #39
    Mar 2010
    where is resistive wire in bmw e46 99 where I connect Joycon?Thanks
  10. #40
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    CarPC joycon is essentially a USB keyboard for the computer, right?
    So extraaha, can you develop a bluetooth version? I wonder what could be done with this to control an iPad, for instance. I know you can connect a bluetooth keyboard, or a usb one, to the iPad, but I think in this case it would be more elegant to use bluetooth.
    Not sure how you control iTunes via keyboard, but it should be possible. A way to change tracks+transport buttons (play/pause/stop/FF/RWD) on the ipad via steerring wheel remote would be awesome, and perhaps a good market for you guys?
  1. Tutorial - Steering Wheel Controls
    By greenman100 in forum FB Documentation and Tutorials
    Last Post: 03-02-2015, 07:19 PM
  2. Replies: 0
    Last Post: 03-02-2010, 06:07 PM
  3. How Can I Build a Steering Wheel Control Interface
    By electro in forum Input Devices
    Last Post: 10-01-2008, 04:34 AM
  4. Steering Wheel Remote Control
    By drdave in forum Car Audio
    Last Post: 02-21-2008, 11:48 PM
  5. Steering Wheel Volume control interface
    By wizbangstokes in forum Input Devices
    Last Post: 10-24-2007, 12:36 AM
Tags for this Thread
