Results 1 to 4 of 4
Thread: Microphone w/ External Phantom Power
    Mar 2010
    I recently installed a cardioid microphone in my car that requires Phantom Power (PE) and since my sound card doesn't provide PE I bought a Behringer PS400 to supply it. The model I bought came with a ac/dc 12V power supply and when I use it, everything works great. After testing I found an old power supply that had same size connector to plug into the PS400 box and wired that connector into my car's 12V power. When I use my car's 12V as the source there is a ton of noise and you can barely make out any words spoken into it. This sort of surprised me since the adaptor was 12 VDC so I thought it would work. Even with engine off and only accessories on, there is still a bunch of noise. To make sure I didn't fry anything I reconnected the provided AC/DC adapter and verified everything still worked, and it does .
    Has anybody had any luck wiring in a mic that required PE like I am doing or maybe used a different Phantom Power supply in their setup that works?
    Or any suggestions on how I can get what I have working?
    My next idea is to buy a phantom power supply that runs off 9V batteries but I'd rather not have to take apart my dash when the batteries die. I also have no idea on how frequent I would have to replace them. If it is once a year that may not be so bad.
    Thanks,
    Bill
    Jan 2008
    so did you hook it up to your cars 12-14v power(unregulated-- like a cigarette lighter port) or your regulated computers power supply, and do you use a inverter?
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    is this a PC microphone that requires phantom or like a standard style mic you would use in a live stage setting. I thought that PE was 48 volts on a standard recording / live mic.
    Mar 2010
    Yah, tried both actually. It was a little better on the PC 12V but still sounded like phone conversations where from a galaxy far beyond (I spliced into 1 of the molex connectors Yellow/Black). I haven't tried an inverter yet but I did purchase one last night off ebay (12VDC/110AC). I'm really hoping that will do the trick. Even though the Behringer PS is listed as a standard 12VDC 150mA supply maybe it's producing another element that is needed.
    It is a standard style mic. It is an Audio-Technica ES947. The PS400 has a toggle for 12V/48V. When I had it working with home's AC power it was switched to 48V setting (I used same setting when running off car power).
  1. Power a DC-DC PSU on a workbench
    By ssteger in forum VaultWiki
    Last Post: 10-14-2009, 05:07 PM
  2. usb dvd case...external power messes up my setup..help!
    By nickfer3 in forum General MP3Car Discussion
    Last Post: 06-21-2008, 06:52 PM
  3. External Hard Drive Power Adapters
    By fatejd in forum General Hardware Discussion
    Last Post: 10-12-2006, 03:36 PM
  4. Replies: 1
    Last Post: 05-16-2005, 10:09 AM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
