Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: rcjoycon on a pontiac trans am
    Jul 2009
    hi im trying to see if anyone has used the rcjoycon to get the steering wheel controls working on a 2002 pontiac trans am. as far as i can tell it has one wire on the radio harness for steering wheel controls.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The wire on the harness is based on 12V and I'm not sure what RCJoyCon takes. The other way to interface is the 4 pin connector under the steering column. I can't remember if it's the 2 inside or 2 outside, but can look. 2 are for the backlights (12V when lights on, and ground) and the other 2 are 12V and the wire that goes to the harness. Find male and female connectors to go inline or clip the 12V and replace it with the RCJoyCon power side.
    Jul 2009
    thanks for the reply curiosity. heres a bit more info on what i have happening
    the joycon is currently hooked up at the harness signal wire is hooked up to to the steering wheel while black is hooked up to ground. the joycon does reconize the button presses but it puts them in a unuasble range.(im guessing the 12v is to much) if i tap into the harness under the column would the signal change.
    heres what the joycon page says
    Converts resistance-output steering wheel remote controller into USB HID keyboard and HID remote controller.
    - Works same as standard USB HID keyboard and HID remote controller by hardware.
    - 24V tolerant 4 channel resistance input.
    - Supports 28 physical buttons, 52 programmable logical buttons.
    - 2 logical button for one physical button, up to 5 simultaneous key strokes by one button.
    - 2 programmable LED port.
    - Remote wake-up(resume PC from sleep with steering wheel remote controller).
    - Temperature range : -40 ~ +85C
    the part in bold if im reading right mean the 12volts should be fine right?
    Mar 2004
    Florence Yall, BFKY
    It's tolerant but that just means safe. It doesn't mean it will work.
    Are the values too high or too low? What is the value when buttons are pressed and when none are pressed?
    Jul 2009
    sorry im still a bit new to this. i dont know if your familiar with the joycon software at all but going by that the when no button is pressed the value is at 230 in the software and when ever i press any button it goues to the max value of 255. all the buttons do this. i was hopeing it was something simple like adind a resistor inline but im begining think its just not going to work.
    Jul 2009
    the other option i was thinking is useing one of the pac modules before the joycon. i was thinking that they may reduce the voltage. i would assume most aftermarket headunits would use a resistive signal. but not to sure about that.
    i dont just suck at spelling i also suck at typing.
    Mar 2004
    Florence Yall, BFKY
    I'm not familiar with it, and don't know if it has it's own resistors. It sounds like it doesn't. If I remember correctly, the button resistors run from 600 to 1.3K ohms and it's open when nothing is pressed. If you have any resistors laying around, put one between the input and ground. My ADC is running 5V through it and uses a 2.5K pulldown, so I'd say test with at least 2, around 4.7K and say 2.2K and see which one gives you better numbers. It should work.
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I'm curious about this as well, since my new software upgrade (Win7 &, CF 3.1) all of a sudden is playing hell with my SWI-X + USB-UIRT. (won't work after hibernation). I was interested in the Joycon EX.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Mar 2004
    Florence Yall, BFKY
    No idea about hibernation but I'm sure you can get it to work. The 255 for all buttons shows that it's just getting a high value instead of variations in voltage. Once a pulldown resistor is in there it will work like a proper divider ladder. Currently it's just like 12V----/\/\/\/---Input (12V)
    Sep 2003
    Tampa, Florida
    So you think inserting a resistor in series with the input may be able to get the resistance down to a point where it's within the joycon's range? Wouldn't that just increase the resistance past the range? I just want to ditch the SWIX-USBUIRT combo, cause then I can ditch Girder, plus a really weird problem when my power windows hit limit (up or down) the USBUIRT stops accepting input for 15 seconds or so. I need a hardwired solution like the Joycon.
    WORKLOG
    Webpage
  1. 2001 Pontiac Trans Am
    By redls1bird in forum Worklogs
    Last Post: 01-20-2013, 11:28 AM
  2. pontiac trans am touchscreen
    By tacobandit in forum Fabrication
    Last Post: 03-14-2008, 05:09 PM
  3. Replies: 9
    Last Post: 03-02-2008, 11:24 PM
  4. MP3Car Trans vs Xenarc 700TSV
    By PatInTheHat in forum LCD/Display
    Last Post: 06-28-2007, 02:47 PM
  5. Pontiac (Based on Orange Heat)
    By Jahntassa in forum CF Skins
    Last Post: 07-21-2005, 01:12 PM
