Results 1 to 5 of 5
Thread: Using two touchscreen panels?
    Low Bitrate atrixstars's Avatar
    Oct 2006
    Does anyone know that if I can install two touchpanel one on top of the other?
    Such as this: linky
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Why would you want to do that? Each touchscreen layer also decreases brightness noticeably.
    Elsewhere
    What do you think you would accomplish by having two touchkits?
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    You can but it wont do anything. There will always be pressure on the "back" one, so it will constantly read something false. And the front might have the same problem, especially if you try and squeeze it in the OEM casing.
    Like DP said, what are you trying to accomplish?
    1.9in x 2.9in -- 47mm x 73mm
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Only logic I can think of is that one is broken and instead of taking it off he rather just put one on top. The other reason is maybe he is adapting a OEM screen to use with the car pc but wants to be able to switch betweeen OEM and PC? If its anything else then I have to ask the same question, why?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  1. 2006 Acura TL OEM Navi Touchscreen Integration
    By met152 in forum Show off your project
    Last Post: 09-24-2010, 10:34 PM
  2. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
  3. Replies: 2
    Last Post: 03-27-2007, 04:28 PM
  4. Problem Identifying Touchscreen Controller
    By yingyang006 in forum Input Devices
    Last Post: 01-08-2007, 09:01 PM
  5. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 02:49 PM
