Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: USB Hub problem
  1. #11
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    The cable from the computer to the hub should be no more than maximum 5 meters. That's the maximum signal length specefied in the USB 2.0 documentation.
    Have something to to about low current and signal noise.
  2. #12
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    500mA is the maximum per port on a USB 2.0 externally powered hub. The PC ports can supply 1A or more. That's why it works that way. Just tap into that supply and power the drive if it has a barral connector or a USB Y if not. It will work fine.
  3. #13
    May 2008
    Beachwood, NJ
    Quote Originally Posted by Curiosity View Post
    gotcha, ill throw that around, due to the lack of space in my dash i had to solder the usb cable directly to the circuit board inside the external drive, so either ill add a power cable, or maybe ill solder a Y USB cable instead.
  1. how to use a USB hub
    By toofresh in forum General Hardware Discussion
    Last Post: 01-22-2009, 06:15 PM
  2. USB DVD connection problem with XP
    By bes51659 in forum General Hardware Discussion
    Last Post: 02-10-2008, 11:15 AM
  3. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 03:42 PM
  4. usb hub problem
    By zyr55 in forum Input Devices
    Last Post: 05-31-2007, 07:58 PM
  5. USB hub does not always initialize on boot
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-29-2006, 03:41 AM
