Results 1 to 3 of 3
Thread: Hacking a remote control into a car steering wheel controls
    May 2010
    I don't have any experience in this but I thought I would give it a go as it seems the cheapest option. I'm wondering if anyone has done this before and can lend me some advice. I've pulled the cars stereo remote apart and I'm wondering If I can drill a small hole onto each side of the button pad's circuit and solder a wire on either side, and add a button in between to complete the circuit. I haven't pulled the steering controls apart yet. I'm wondering what type of button would be suitable for the steering wheel controls, it would need to complete the circuit once pushed then open after letting go so as to not drain the remotes battery. Also is it stupid to try and mount it inside the steering wheel. I'll post some pics tomorrow when I get the chance.
    May 2009
    You'd better use Resistive remote controller circuit.
    It is very simple circuit.
    But if you want to mount the remote controller on the steering wheel(the rotating part), you will need clock spring.
    Or to avoid mounting clock spring, you can mount the remote controller on the neck of the steering wheel(the non rotating part).
    May 2010
    I started to go down this path but couldn't figure out a nice mouting solution (didn't want to mess up my steering wheel). In the end I used my mobile phone with the software Vectir Bluetooth Remote Control. I now have my phone in a holder mounted on the dash just to the side of the steering wheel. When Vectir is running, I can control Winamp by pressing buttons on my phone. It works over Bluetooth (or WiFi) which obviously saves the hassle with the wiring and steering wheel mounting etc.
  1. BMW E60 install and I-Bus retrofit....tricky
    By Craggy in forum General Hardware Discussion
    Last Post: 11-17-2010, 05:06 AM
  2. Scion Xb Steering wheel control
    By marc2912 in forum Newbie
    Last Post: 09-16-2009, 09:01 PM
  3. 07 Scion tC Steering Wheel Control Guide
    By stealinfool in forum FB Documentation and Tutorials
    Last Post: 04-12-2009, 04:35 AM
  4. Replies: 2
    Last Post: 05-23-2006, 12:56 PM
  5. GM Steering wheel control interface
    By S7347H in forum Input Devices
    Last Post: 04-14-2005, 02:17 AM
