Results 1 to 4 of 4
Thread: What if I run Mediaengine as a shell? Touscreen still works?
    Apr 2002
    socal
    Will the touchscreen still work (digitalww 7" usb) if I run Media Engine as a default shell? Only reason I am asking because I know that windows has to load up the touchscreen prog (in the tray) for it to work and if I close the prog, the touchscreen will not work anymore.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I would think so.
    Aug 1999
    Upper Marlboro, MD 20772
    he will need to go into registry and add that driver to the runonce or runatonce section. make it the first thing that loads on the list
    abcd-1
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    works anyways. just load to windows to calibrate it first, then you should be ok.
