Results 1 to 10 of 16
Thread: Need help with touch screen!
    Jun 2010
    Exclamation Need help with touch screen!
    I bought a Jensen 7" motorized touch screen multimedia reciever for my car and the unit stopped working...the touch screen still works though. I was wanting to take it apart and use the screen as a VGA touch screen. Only problem is that the reviever wasnt made to plug a VGA into it. Is there a way that i can make this happen?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    what kind of connector does it use? If its rca you could use a cheesebox, but more than likely its some proprietary ribbon, in which case you'd need to find a pin-out to see what you could do with it
    Live mp3Car Facebook Chat
    Jun 2010
    I havent taken it apart yet. i want it to work like a normal VGA touch screen would if possible. here are some pics.
    Elsewhere
    Good luck w/ that.
    There is someone who did this w/ a Kenwood unit, and posted a how-to.
    There was some reverse-engineering involved, as I recall.
    How about the Wiki?
    Woodbridge, VA
    Blog Entries
    55
    well it appears you have composite connections (yellow video cable). Provided you have the ability to switch the device to Video1 through the monitor, you would need to purchase a cheesebox to convert that to a vga signal. Be warned though the resolutions will be limited and the quality will suffer when compared to a true VGA screen.
    Jun 2010
    will i be able to control the mouse and other functions by touching the screen like a reguar VGA touch screen? my vision i have is to take the whole screen out and make a fiberglass enclosure for it and mount it somewhere in my car. didnt know if i made that clear...
    Jun 2010
    @DarquePervert do you know where i can find the how-to that you mentioned?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You need to take it apart and look. It's busted already, anyhow, right? So, you can't bust it any more by taking it apart.
    You'll need to look at the ribbon cable that goes from the touch screen to the electronics inside. Likely what you'll find is something like a plug on the main board that the ribbon connects to. The controller for the touch screen will most likely be integrated into that board, making it impossible to use for a PC.
    In which case, you'll need to purchase a USB controller for the touch screen PROVIDED that the touch screen is the standard 4 or 5 wire resistive type. You won't know until you get in there.
    A new touchscreen and USB controller can be had for about $60 on ebay if you look hard enough.
    If you are successful, in the end, you'll have a sub-standard composite video display that will be blurry with text below about 14 points or so, washed out colors, and a hacked together touchscreen to control it.
    That may be okay with you, or you may just want to budget for a real VGA touchscreen
    Want to:
    Jun 2010
    well id really like a decent picture on the screen. is there anything i can do with it? i hate to just throw away a working touchscreen. ill post pics once i get it open...im just waiting to see if i can get my money back before i go ripping into it.
    Jun 2010
    anything creative i can do with it?
  1. Fixing my touch screen
    By Woofnstuff in forum LCD/Display
    Last Post: 12-14-2008, 05:10 PM
  2. Replies: 0
    Last Post: 10-05-2008, 01:18 PM
  3. In-dash touch screen vs touch screen overlay
    By vxcarpc in forum LCD/Display
    Last Post: 09-22-2008, 11:52 PM
  4. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 05:20 PM
  5. task switching? touch screen only
    By chuckctv in forum Software & Software Development
    Last Post: 09-04-2004, 10:50 PM
Tags for this Thread
