i know that some have run into problems running some devices through a hub, so you might want to experiment first with all the devices first.
primarily, you might want to consider at least keeping the monitor on a second plug, so you can still control the pc if your hub were to go bad..
for power, usb specs say that any single usb port cannot output any more then 500mA, so it is usually easiest to get a rough estimate of power requirements by adding up devices assuming that they pull the full 500mA from each port... this is not completely realistic for most devices, but will give you some overhead for power as well...
also, if you haven't seen it yet, check out bugbyte's old install, he had also created a docking solution for a mac mini in his car..
LinkBack URL
About LinkBacks
