Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: PowerMate Controller
  1. #11
    Mar 2001
    You have to order it from Griffintechnology
    Anyway I bought it and I'm a bit disappointed with the long-click and click-rotate functions. Basically if you push and rotate, it'll do the 'click' function or 'long-click' (If you took too long to rotate) no matter what.
    So say in winamp, if you set rotate to volume, click to mute, press-rotate to scroll through playlist, and long-click to play track.. then anytime you try to scroll through the playlist, you will *always* either mute or change tracks when you let go.
    I emailed them asking if there was a way around this that I didn't understand and received no response.
    The controller itself seems quite neat and well built, but it doesn't seem like the click and long-click are usable in combination with press-rotate. You have to pick, either or.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
  2. #12
    Jul 2003
    agreed
    I have the same problem...hopefully they will update software for this, as well as adding double click
  3. #13
    Sep 2000
    LA, CA, USA
    I'm thinking about getting one of these.... which means you might see media engine support for it one day.
  4. #14
    Jul 2003
    not like i would be that hard to support....all it does is send keys
  5. #15
    Sep 2000
    LA, CA, USA
    yes, but to support it without installing the griffin software and to be able to control all functions of the program exclusively with the powermate.
