Results 1 to 2 of 2
Thread: Alpine 9883 Aux input extremely quiet
    Dec 2010
    Hey,
    So I recently installed an ai-net to 3.5mm jack cable to my alpine 9883 stereo so I that I can play audio from phone. Problem is, when I set it to aux mode and turn on the music, it comes through, but very very quietly; I have to crank the volume just to hear it.
    Anyone have any thoughts as to why this is the case? Grounding issues possibly?
    Thanks for any help!
    Jan 2008
    i am not too familiar with alpines, but haven't seen many others posting about them(this forum is primarily for installing computers in cars), so..
    my pioneers used to have a aux input level adjustment to help make it louder. not sure if alpine has the same feature..
    also, make sure that your devices headphone output is as loud as it will go..
    to my limited knowledge, most aux input adapters for radios are mostly isolated, so i don't believe it should be a grounding issue, though i've been wrong before..
    if possible, maybe try some other devices? both plugged into car power, and unplugged?
    it might also be worthwhile to attempt to reslot the connector-- maybe it is 'just' barely connected, and is causing the problem.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  1. Extremely low volume with auxiliary input
    By puter in forum Car Audio
    Last Post: 02-06-2008, 12:42 PM
  2. FS Ford OEM stereo AUX input connector unit
    By Davefocus in forum Classified Archive
    Last Post: 08-17-2006, 02:49 AM
  3. Requests
    By CdRsKuLL in forum FreeDrive
    Last Post: 08-11-2006, 05:09 AM
  4. RCA Aux Input Switch Toggle
    By mrmarbles in forum Newbie
    Last Post: 11-04-2005, 03:56 PM
  5. AUX input alternative
    By Pariah in forum General Hardware Discussion
    Last Post: 12-08-2003, 12:54 PM
