Results 1 to 7 of 7
Thread: need your help with physical button inputs
    Feb 2009
    Hi All
    I want to connect 12 push buttons (non latching type) 2 rotary encoders and 3 LED's to my carpc, i want all the physical buttons to execute RR commands when they are pressed e.g. change skin, turn volume up/down and i want the LEDs to be controlled by indicators from ride runner.
    I was thinking of using the u-hid controller to do all this but i haven't seen anyone on here that is using this controller with ride runner, does anyone have any other ideas of how i can get all this to work
    Matt
    Jan 2008
    how did i get here before 2k1toaster?
    anways, i think the fusion brain will do it(someone else will need to confirm)
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jun 2008
    Perth, Western Australia
    You could use a Fusion Brain to do the above (Not 100% sure about the rotary encoder...maybe check with 2k1toaster), with the added bonus of still having some spare I/O channels for other things down the track.
    Price for the FB is pretty low, especially for what it offers, it works with RR, and it supports an mp3car member!
    Edit: Dammit...I knew I shouldn't have gone to butter my toast and left this window open...beaten by 2 minutes!
    Jan 2008
    your toast's getting cold
    i know i have read that the FB will work with rotary encoders, the specific limitation that i question is if it has enough inputs/outputs for all 12 switches, 2 rotary encoders, and 2 led's.. of course, you could use more then one FB, and i believe i read somewhere that the software allows for it, but can't help much more then knowing the idea is feasible...
    HID retro--100%
    Jun 2008
    If the switches aren't going to be pressed all at the same time, you could possibly use a resistor ladder and group say 5 or 6 buttons onto one input.
    Then just run 5V through the lead, button 1 drops the voltage to 4.5v, button 2 drops the voltage to 4v, etc?
    And the toast was mighty hot indeed!! lol
    Feb 2009
    thats great news about the FB, so just to confirm i should be able to connect all my switches, encoders and LEDs to the fusion brain and i can program the FB so that when i press one of the physical button it could change skins for example, or when i turn the encoder it will turn the pc volume up or down etc... I have search this forum trying to find documentation on the FB and could find anything, does anyone know if there are any guides etc... so would i connect the push buttons/encoders to the analogue inputs or the digital outputs?? could someone explain what the difference between all the inputs/output are
    Thanks again
    Matt
    Jan 2008
    your best bet might be to pm 2k1toaster for that info-- he's the creator of the fusion brain, so he would know best..
    HID retro--100%
  1. Need ideas on how to push physical button (relay) with computer
    By dhantiflag in forum Hardware Development
    Last Post: 06-30-2011, 02:30 PM
  2. physical input to mac
    By schnaarf in forum MacCar
    Last Post: 04-26-2008, 05:23 AM
  3. Lilliput EBY-701 - physical dimensions
    By Brycestro in forum LCD/Display
    Last Post: 02-25-2007, 11:37 AM
  4. physical shipments
    By dmc in forum StreetDeck
    Last Post: 07-12-2006, 12:47 PM
  5. Front Row Remote (Physical)
    By wheli in forum MacCar
    Last Post: 05-04-2006, 05:44 PM
