Results 1 to 3 of 3
Thread: Directed HD Radio Causing static in factory radio
    Mar 2011
    Hi,
    I currently have my directed hd radio wired up to the +12V output of my carnetix P1900 power supply. It is set to FM modulation for audio output. The +19V output of the carnetix is tied to the input for my laptop. When the HD radio is not powered on, I have good reception when the Directed HD radio is disconnected from the carnetix. When the radio is connected and turned on, there is static and distortion on the stereo radio. I tried tying the hd radio return directly to the chassis of the car. I also tried soldering the RCA returns to chassis but it did not improve the static. Does anyone else have this problem and have any idea how I can fix this? Thanks!
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Could be a bad radio unit
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Jan 2004
    Chicago, Illinois USA
    This sounds like a very common problem which is solvable - but from your description I can't tell if you have tried it. Here a link to the solution: http://www.rush2112.net/phpBB3/viewtopic.php?f=11&t=774 It made a night and day difference for me.
    2000 Audio A4 Avant
    CARPC --- 95% Complete / -50% WAF (wife acceptance factor)
    • Intel D525
    • Xonar DS
    • Mo-Co-So Case
    • Xenarc 706TSA
    • Directed HDRadio
    • RideRunner w/ Modified Reborn Skin
    • Winamp
    • ASIO 2.1
    • Console
    • Windows 7
  1. Directed HD Radio Antenna?
    By MachinasDei in forum The FAQ Emporium
    Last Post: 06-07-2011, 12:28 PM
  2. Directed HD Connect Car Radio
    By southernford246 in forum Car Audio
    Last Post: 02-13-2011, 12:35 AM
  3. Directed HD Radio Static Problems
    By mattstevenson in forum General Hardware Discussion
    Last Post: 05-01-2009, 03:01 PM
  4. Directed HD Radio static and popping
    By ClassicStyle in forum Car Audio
    Last Post: 04-24-2009, 10:11 PM
  5. Directed Electronics HD Radio
    By DaveDog in forum General Hardware Discussion
    Last Post: 05-23-2007, 09:06 AM
