Results 1 to 6 of 6
Thread: Joycon and Mondeo MK2 steering wheel controls
    Nov 2007
    london
    Hi Guys my joycon arrived today, now how do i connect it? The yellow Plug for the steering wheel controls has 3 wires for it, which 2 do i use?
    Any help would be great as my gear stick gets in the way of the volume control on centrafuse
    Adz
    Nov 2007
    london
    Ok got it connected but the joycon explorer says only one button detected?
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    if the wires you found for your stock steering wheel control wires has three wire, more than likely you have 1 ground wire and two control wire. so on the joy con , one input will be ground and the other two will be the other inputs. connect it as per instructions and run joy con explorer to find which wire does what and assign them to a keyboard stroke. run centrafuse and map the keys out..
    follow the vid too.. http://www.youtube.com/watch?v=JtzPmfz6J4o
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Nov 2007
    london
    Found that one was a speed signal wire so didnt connect that, but the other 2 are ground and date, but it only shows one button, even adjusting the pot on the board doesnt show any more buttons
    Adz
    Aug 2007
    Queens, NYC
    you may have to search for more wires......
    CarPc
    Project "Driver"
    Planning [99.9%]
    May 2009
    Because Ford Mondeo 96-00 Radio controller is not resistive, you need a Resistive Button PCB that converts it into resistive controls.
    PDF version
    http://www.changjack.com/KN/1045/KN1...stallation.pdf
  1. CarPC JoyCon - Steering wheel remote interface
    By SoulR in forum Input Devices
    Last Post: 08-25-2011, 01:04 PM
  2. Joycon Ex and Ford/Microsoft Sync Steering Wheel Controls
    By Mears in forum General Hardware Discussion
    Last Post: 08-18-2010, 09:05 PM
  3. Replies: 2
    Last Post: 06-23-2009, 11:13 AM
