Results 1 to 10 of 11
Thread: Directed HD Radio with Centrafuse. cannot control volume.. HELP!
    Aug 2009
    Hey everyone,
    Here is my problem... I just the recently picked up the directed HD radio receiver and Mitch's cable. I am using centrafuse 3.5 with windows 7. I hooked everything up and started up centrafuse and when I turn on the radio in centrafuse the radio comes on clear and great except I cannot control the volume. It comes on so loud I have to turn it off almost right away but I have tried to turn down the volume and mute the volume but neither work when the radio is going. The volume bar moves but the volume doesn't actually change. If i play music off my hard drive the volume works fine. Is there a setting or driver that I am missing. Thanks!
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    I think you have to change the settings in centrafuse to also control
    The line in/mic volume. Make sure the line in volume is activated as not grayed out in the windows audio control
    Panel area. Start there I guess.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    MySQL Error
    Oct 2004
    its all about understanding how audio works in windows...
    and to some part how you did the audio setup for hdradio in CF
    (which is vague at best)
    but dont mix buffered and non buffered audio
    my recomendation is non buffered, since the buffered audio is buggy in CF
    so the PLAYBACK line is set to where you have it connected (good luck with CF)
    and none for record(buffered)
    you might need to manually tweak the line in volume, outside of CF...
    but the master volume controls the master volume
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2009
    thanks for the reply! I understand what you are saying and it makes sense. But under record buffer on I have two choices.. default and microphone (high definition audio device) and under passthrough line in I also only have two choices.. default and speakers (high definition audio). Therefore I can not select none and I also can't remove or add any options. Any ideas? thanks again!
    Aug 2009
    I tried switching the inputs around and did not make a difference. Looked at windows settings and found nothing. Any ideas on how to select none or another input option?
    MySQL Error
    Oct 2004
    can i assume windows 7?
    did you install the manafactures Drivers?? the windows ones wont do what you need!
    and the PLAYBACK side of the mixer, is under SPEAKERS
    again its going back to understanding audio in windows...most people DONT!!!!
    i didnt until i had to...
    but keep in mind this is not your only area of concern, its the program your using to access the radio
    it has audio management too (if its CF, buggy at best)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2009
    Yes I am using Windows 7. I installed the correct plugins and changed the settings and still nothing. I am not using a head unit so everything goes into the computer and my 4 channel amp. Regular music works great. I have tried usb sound cards, etc.. Not sure what else to do. It is like it is connected straight to amp because I can only turn it down by adjusting the amp but it is plugged into the sound card..
    MySQL Error
    Oct 2004
    well.. if it does... cf controls the mast volume of the pc...so anything coming out of the pc would have volume control...
    i dont know about plugins... but you MUST have the audio drivers installed...
    and maybe a little understanding of how audio works on PCS
    but i can assure you it all works with CF
    with out knowing all the details of your audio system, its best you solve this problem...work it out
    1 connection from hd radio to pc, how it is done
    2 am i using bufffered, or direct playback
    3. if buffered, the direct playback mixer input MUST be muted or it will echo
    4. if direct, no buffered audio mixer input should be specified or it will echo
    all this assumes the speakers and hd radio input are on the SAME sound device
    m
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    and one thing with CF 90% of the time you cant choose the right line for playback, due to bad code in CF!!!
    (specially on win7)
    so i wish you LUCK big time with CF
    i just looked at my cf 4, and i cant pick the right input!
    bad coding in CF
    i told them about it years ago
    see i click on passthrou line in device... and it lists OUTPUTS!!!!! useless!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    one, do buffered off, and leave both at default
    go to windows mixer, unmute the line in (that your connected to), set the volume of the input
    and call it that
    since my code will mute and unmute the HW (providing your using my cable)
    when radio is active, it will unmute at the radio hw level..
    and when you go to now playing or whatnot, it should mute radio
    it does here
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Directed HD Radio Causing static in factory radio
    By bchiang in forum Input Devices
    Last Post: 09-28-2011, 07:10 PM
  2. I am lost with Directed HD Radio
    By Miguel_R1 in forum Road Runner
    Last Post: 02-18-2010, 10:19 PM
  3. OEM Radio Integration - Volume Control
    By canadiandream in forum Input Devices
    Last Post: 08-24-2009, 10:40 PM
  4. Directed Electronics HD Radio
    By DaveDog in forum General Hardware Discussion
    Last Post: 05-23-2007, 10:06 AM
  5. FM Radio- VOlume controls- Mute line-in- control master
    By live2themaxuk in forum FrodoPlayer
    Last Post: 11-16-2004, 03:33 AM
