For those of you who measured the voltage from the hub on the upstream port, was the voltage present on the 5v power line or the data line?
Since the hub is powered, I'm wondering if simply disconnecting the 5v line between the PC and the hub would solve the problem. Of course that doesn't help if the voltage somehow leaks to the USB D+ line.
LinkBack URL
About LinkBacks
