Results 1 to 10 of 13
Thread: OBDI PC interface
    Jun 2003
    Memphis - TN
    OBDI PC interface
    Anyone know where to get some type of interface for OBDI ECUs to connect and pull data to a PC?
    Im building a HUD (HEADS UP DISPLAY) and Id rather have something besides visualizations and song titles as well as temperatures.
    I know there are OBDII interfaces like AutoTap.com
    But I need OBDI. Anything you guy know that I maybe can wire up manually to pull the data, like adding a sensor or what not?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    OBDI was much less standardized than OBDII so you have to search for vehicle specific information.
    What are you using to make the HUD, one of those reflective films on the inside of the windshield?
    Jun 2003
    Memphis - TN
    Unsure which film your referring to (IF you know of one by all means
    I work a second job @ a car customizing shop and we had a vette with a HUD.
    Looking @ the setup it looked like basically an LCD w/ a mirror that reflects it on the windshield.
    I know vettes have a film made ino the windshield to reflect, but Im unsure if I really need it. well have to see.
    http://www.gideontech.com/guides/lcd/
    thats the info on connecting up the LCD.
    I know ODBI was less standardized, but I was wondering if there was a stand alone system that will pull info into a PC using its own sensors. I can connect sensors, thats not a problem, I just dont know of any out there. Im looking for resonably priced
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    You do need the film, unless you want two fuzzy images ofset by about .1 inches. And you could probably get a ADC probe card by ti or something of the like off ebay to which you could connect your own sensors to. I think there's been some talk of that before on here.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    May 2002
    Ohio
    I don't think your lcd will work for a hud unless you put a backliht behind it and a bright on at that. LCD's don't give out light they block it or let it pass through so there won't be any light coming out to reflect off the windshield. Also you will need some kind of reflective film on the window of the light will just pass through
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    How are you gonna mirror the image so that when you look at the windshield its the right image? That's the only major problem I've encountered. Also even with the film you'll still see doubles. Only its not as bad with out the film
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Meridian, Mississippi
    Ok since I have worked in the windshield repair bizzness for some time I know that every windshield has to have a film. If they didnt then there would be alot of blind people in the world. The film in the windshield is designed to hold it together untill you can get repaired. Now there could be a strip in the vette's windsheild that would allow for easier viewing durning day time driving but a light strip of tint would work just as well. A very light tint
    You can get by without the film for a while but your hud would need to be bright as hell for driving durning the day. I would suggest a red color hud since red is the easiest on the eyes.
    I would send an e-mail to autotap about a OBDI conenction. I want to say they have something for that type of system. Or at least I remember reading they did.
    Jun 2003
    Memphis - TN
    http://www.dupont.com/safetyglass/lgn/stories/1004.html
    "Delphi Delco Electronic Systems of Kokomo, Indiana (USA) is the world's leading supplier of automotive Heads-Up Display (HUD) units which depend on a wedge-shaped PVB interlayer in the car's windscreen for optimal visibility."
    Jul 2003
    Thats another thought Custommx3, but I didnt see anywhere on where to buy it but then again all I did was glace over it.
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    http://www.machv.com/headupdisspe.html
    The kit comes with some stick-on film. You can probably find out what it is and get just the film.
    The best way I know to reverse an entire monitor image is to use the NVKeystone utility distributed with the NVidia driver. I don't know what chipset it requires (probably GF4MX at least), but it is capable of reversing the entire screen image. I use NVKeystone all the time with projectors to distort the entire desktop and have used it to do rear/ceiling projection on projectors that did not support it. NVKeystone is by far the best utility when you need your entire screen distorted for whatever reason. The only real problem with it is that it's not possible to get a pixel-accurate horizontal or vertical flip. Everything is just a little blurry (fine for presentations or something).. also the framerate suffers the larger your screensize is.. 800x600 flipped is great, 1600x1200 flipped is not!
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
