Results 1 to 5 of 5
Thread: Installing a camera? BEWARE of crappy OEM cables
    Nov 2012
    I was installing cameras (front and rear) and noticed a lot of picture "noise".
    I inspected the signal cables and found TWIN LEAD!
    WTF?
    I replaced with a good coax and SURPRISE, no noise!
    A note to the CHINA vendors, get your act together.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    I also came across this last year. Older systems I worked with always used coax, not just for noise but for resolution (hi-freq roll off) and impedance matching. There are a lot of cameras including name brands that are no longer using coax for video including name brand security multi camera systems with 100 feet runs of cable with coax connectors at each end of this unshielded cable. And NO - these are not base-band video or balanced video systems.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Raw Wave
    Nov 2009
    But many those systems use CAT-5 cable etc...
    But - there those that only use twin.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    However the systems I mentioned don't use CAT-5 and all cables are supplied and terminated by the manufacture. The last few cameras I tested for vehicle installation did not use shielded cable but ran standard CVBS over a non-twisted pair to standard monitor inputs.
    Nov 2012
    Most of the China sellers use the same cable they used for the power for the signal. IMO
    I heard back from the supplier and he asked me to take pictures.
    I told him to go plug one in and compare for himself.
    The install I am doing is the front and the under hood electrical noise I am sure would play hell with the picture.
    it looked bad enough without the engine running.
  1. Replies: 4
    Last Post: 08-29-2005, 09:13 PM
  2. Nissan 100 NX (1600) Part I (installing cables and layout)
    By videodok in forum Show off your project
    Last Post: 08-25-2005, 04:50 PM
  3. Advice on Installing Power Cables
    By SimonTALM in forum Newbie
    Last Post: 08-05-2005, 09:41 PM
  4. USB 1.1 DVD - too crappy?
    By cybermob2 in forum General Hardware Discussion
    Last Post: 04-02-2004, 02:02 PM
  5. crappy heat-shrunk xenarc cables?
    By paulpv in forum LCD/Display
    Last Post: 01-15-2004, 11:01 AM
