Results 1 to 9 of 9
Thread: Recommended usb keyboard button emulator?
    May 2013
    Melbourne, Australia
    Hi,
    my first post on MP3Car, such a great resource
    I'm almost at the point of installing my CarPC in a 2006 Mazda 3 MPS, consisting of a mini ITX setup, Carnetix PSU and 7" touch panel. The touch panel is the most interesting as I'm housing it in a flip-up housing that previously held a "Chinese GPS" unit that proved largely useless for my needs.
    Link to unit:
    http://www.ebay.com.au/itm/190817606...84.m1423.l2649
    Under the screen there are six physical buttons I'd like to utilise under Windows. I'm happy enough to wire up a custom PCB with proper switch placement but am not sure on what sort of device I should use to emulate key presses. Would that be something like an iPac ($$) or is there a considerably cheaper option out there?
    JB
    Jan 2008
    if i remember right, there is code somewhere to use an arduino for the same purpose.
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    Quote Originally Posted by soundman98 View Post
    This code I need please, if anyone has it available .
    Thanks in advance,
    Dave
    Vauxhall Astra SXi Car PC installed.
    Constant Bitrate ephect's Avatar
    Jul 2007
    i have one of these for my mame machine: http://www.ultimarc.com/ipac1.html
    no reason you cant utilise this in the car, standard cat5 cable works great for wire runs if you dont have room available in the area where the buttons are. i picked mine up from these guys http://ozstick.com.au/
    Mar 2005
    Norfolk UK
    I already have the Arduino Uno R3 and nano, and really want to utilise these for steering wheel resistive ladders, etc. If anyone has the Arduino code I would be really grateful .
    Thanks in advance,
    Dave
    Sent using Tapatalk 2
    Jul 2007
    lol i was replying to the OP as he didnt mention anything about resistive buttons.
    Mar 2005
    Norfolk UK
    Quote Originally Posted by ephect View Post
    No Probs. I realised that but thought I ask since someone had already replied with it as a possible solution .
    Maybe I'll get lucky....
    Cheers,
    Dave
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    You could always use a joycon I've got one for my steering wheel and it works very well.it can cope with about 28 physical buttons and its pretty simple to setup. http://rcjoycon.com/base_3//menu_10....m_board_idx=16
    I would also be interested in the code for the arduino if anyone has some info.
    Sent from my GT-N7000 using Tapatalk 2
    May 2013
    Thanks all for the tips - I recently built up a cocktail arcade cabinet using an Ultimarc JAMMA adapter, so funny how the CarPC project uses the same sort of stuff Another utility found online remaps keyboard commands to joystick buttons - I've a few generic USB gamepads which might work (I've only about six buttons I want to make, after all):
    http://www.emulation-evolved.net/?q=node/19
    Will also look into joycon adapter.
  1. Customizable 3 Button Keyboard
    By darkslyde in forum Input Devices
    Last Post: 02-12-2008, 04:40 PM
  2. f/s: mobo, amd proc, keyboard emulator
    By scott_fx in forum Classified Archive
    Last Post: 03-30-2005, 08:03 PM
  3. f/s: mobo, amd proc, keyboard emulator
    Last Post: 02-22-2005, 04:00 PM
  4. keyboard emulator board
    By joelw23 in forum Input Devices
    Last Post: 02-15-2005, 01:50 PM
  5. Keyboard Emulator?
    By jkotecki in forum General Hardware Discussion
    Last Post: 07-20-2000, 01:03 AM
