Results 1 to 6 of 6
Thread: anyone use volumouse?
    Mar 2009
    I've downloaded volumouse with a view to using a modified mouse to control the volume in centrafuse. The problem i have is when i press a button in centrafuse volumouse won't work until i click back on the desktop the it works fine .
    Has anyone encountered this problem before.
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    I believe the button for Cfs volume control is alt+d5 and alt+d4 just remapp them and your good to go
    Mar 2009
    Thanks for the reply. You are correct about the alt+4 and alt+5 buttons, could explain what you mean by remap them. I can't see how these are controlled by volumouse.
    I'm sure this is a simple but a novice like me, i'm struggling.
    Nov 2011
    Oh just set volumouse to use the alt+ buttons if you can configure it that way....I have set cf4 to use other buttons...(under advanced settings /hotkeys) but last time I did this for volume I had some small issues.give it a go as you can always change it back
    Mar 2009
    I'm still not getting anywhere. I can get it to work with every program apart from centrafuse, how typical is that.
    Mar 2009
    Ok a small development i have volumouse set to only work in centrafuse which works as it should unless centrafuse in the active window. If centrafuse is highlighted in the taskbar it wont work.
  1. RR, Volumouse, Kx drivers
    By canadiandream in forum Road Runner
    Last Post: 10-23-2009, 03:56 PM
  2. volumouse
    By NotchbackVW in forum Software & Software Development
    Last Post: 05-24-2006, 12:24 AM
