Digitalww touchscreen and 5.6" dscustoms indash screen
I am sure some of you have done this. How tough is the install, does everything still work and close properly, how is the visibility/brightness?
Thanks,
Dan
I have got a DC Customs screen setup with a touch kit from 3m, which is probably similar to the setup from digitalww.
How tough is the install?
It probably took me about 2 hours of fiddeling to get all the cables routed correctly and the overlay installed/
Does everything still close ok
I got it all to fit ok, its a little tight and you have to be carefull when trying to close everything, but it works. You may have different results with the digitalww setup though.
Hows the brightness?
Again, it may be different with the digitalww setup, but my brightness was only slightly affected, nothing major.
90% Done
60W DC-DC & shutdown controller
Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
All in a shiny White 2000 V6 Mustang
Click here to visit my NEW PhotoAlbum
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
