Results 1 to 6 of 6
Thread: JoyCon Question!
    Mar 2014
    Question JoyCon Question!
    Hi!
    Quick question, hopefully it was just so simple that I overlooked it somehow.
    I have an E38 BMW 7 series (with DSP) and planning a full Nexus7 build. With the JoyCon, would I lose Cruise Control with removing all factory units (CD Changer, Navigation, and the in-dash unit)?
    Mar 2014
    Excellent! Thanks Enforcer!
    Out of curiosity, is there any specific need for an iBus interface? Is it just to read more of the computer's messages that I wouldn't get from an OBD2 scanner? Or is it far more necessary? (terror)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It would allow you to use the steering wheel buttons instead of using joycon.
    But then it would give some other things as well.
    Not sure how much is on the E38 compared to say the E46 and E39.
    Sep 2012
    Germany - Munich
    If you only have a obd lm317(hope that's the correct name) interface, you can do lot of more things with ibus.
    if you have an ediabas interface, you can do more things as ibus. but it is difficult to inplement the software to a carpc front end or android.
    e38 and e39 have nearly the same hardware. when they have the same production year.
    i think ibus is the best solution.
    Mar 2014
    Thanks guys!
    I didn't know that about the iBus and controlling it, and I'll definitely work on implementing it for v2 of my build. (Mostly because there's an iBus interface by Resler that is backordered for a while and I'm not keen on the available apps working it, I'll let them mature a bit more). Using the Joycon, however, will give me all the functionality I desire (and then some) with hopefully fewer headaches. I'm hoping to get it up and running in a month -- and, if all goes according to my plan, there might be quite a few more E38 owners snooping about here!
    (To my knowledge only a handful of DSP E38s have been done, and none as extensive AND OEM looking as what I'm planning!)
    I'll keep everyone updated as soon as I begin!
  1. Relay resistance when using joycon question
    By Champak in forum Input Devices
    Last Post: 06-05-2013, 09:57 PM
  2. Joycon Help
    By naiku in forum Newbie
    Last Post: 04-10-2013, 08:31 PM
  3. Replies: 3
    Last Post: 12-02-2012, 10:49 AM
  4. joycon
    By nelissen in forum Input Devices
    Last Post: 11-21-2012, 04:25 PM
  5. JoyCon EX Question
    By 4ofakind in forum Input Devices
    Last Post: 09-21-2012, 11:44 PM
