Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: CarPc Joycon Exd USB power?
  1. #11
    Aug 2014
    Yes, you can power a phone while connected to the Joycon Exd by splitting the USB cable.
    But the phone will never draw more than 500mA.
    If you want to run any navigation app that uses GPS and keeps the screen on, this won't be sufficient and the phone will discharge since it will be consuming more than 500mA.
    The only way to allow a phone to received more than 500mA is to short the data pins at the phone end of the cable - which of course then means it can't connect to the Joycon over USB.
    The only solution to this would be a viable Bluetooth interface for the Joycon Exd. Which I've yet to find ...
  2. #12
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    OK, I KNOW it can be done, but with a little circuit trickery.
    What you would need to do is add a small time delay relay circuit to the Joycon, such that when you depress a steering wheel button, and the Joycon detects it, it outputs a signal to switch the relay, which you wire to open the normally closed D+ and D- and hold it open for say 30 seconds to allow the Joycon as being connected.
    You would need to find out what the shorting resistor value typically used for the D+ and D-, and add that value of resistance into the N.C. circuit, probably 100-1K ohms would work fine. This is just a safety feature to protect the USB controller on your phone.
    So you press a steering wheel button of choice, the relay opens, a few seconds later your Joycon is detected as connected by your phone, you use the buttons you want, like volume, next track, etc...
    After the timeout period the relay closes again, and say 100 ohm resistor is effectively shorted across the D+ and D-, and your phone starts charging again.
    Too much work? Just wire in a data shorting switch somewhere to toggle between Joycon or Phone Charging.
  1. WTD - CarPC JoyCon
    By Dave One in forum Classifieds
    Last Post: 05-14-2014, 04:37 PM
  2. CarPC JoyCon Exd was released
    By extraaha in forum Input Devices
    Last Post: 08-21-2013, 05:27 PM
  3. Replies: 3
    Last Post: 12-02-2012, 10:49 AM
  4. CarPC JoyCon EXR VERY slow boot
    By Dahlia in forum Input Devices
    Last Post: 12-12-2011, 08:27 AM
  5. CarPC JoyCon in 07 Saab 93
    By stevent76 in forum Input Devices
    Last Post: 07-21-2010, 05:06 PM
