Mastero IR device - causing lock-up?
I plugged the mastero IR device into my serial port and windows hung. I tried again and it boots fine (so who knows), but it does not appear to register anything. Isn't the LED supposed to go off when it received an infrared signal? Is there anything I need to set in the system first (before I start fooling with girder, etc.)?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
