Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 72
Thread: PDA for remote
  1. #41
    Mar 2004
    There should be a VNC client for Pocket PC as well.
    http://www.cs.utah.edu/~midgley/wince/vnc.html
  2. #42
    Jun 2004
    Central California
    Thanks..
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
  3. #43
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    Sorry, I've been gone a LONG time. Been developing Event Sinks for a new IT company. Now I'm their head network engineer! (FINALLY!) So, I've just reviewed all the updates...
    Bluetooth:
    Yes, bluetooth is a possibility. Here's the catch, in order to use bluetooth, you need to set it up as a peer2peer network. That's easy to do. However, bluetooth only travels so far. I believe class 3 BT has a 33Ft distance, and class 1 has a 300ft distance, but I could be backwards on my classes. However, you can imagine that the BT in your laptop or PDA is the 33ft class. There are, however, routers that have the 300ft range bt. You can use that if you wanted as your link.
    VNC:
    VNC isn't really that secure, but you'd need to know specifics to get in. However, if someone knew your netbios name of your carputer, they'd be able to get in. This is why I perfer to write my own code. That way you don't have to worry about other people with the same idea. However, VNC is used as remote desktop software, where as I perfer to send short txt msgs over the network for low bandwidth usage. Especially if you plan to stream A/V over to the PDA, you're going to need that bandwidth. For me, I'll be placing a camera in my car that moves on a tilt/pan stand so I can see what's going on around my car... I'm very paranoid. Like-wise, you can use it for other streams.
    I must have just dug this topic up.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  4. #44
    Aug 2004
    Nebraska
    Palm users go here http://www.softick.com/ppp/ to get your PPP software. Works great for me.
    2004 Nissan 350z Daytona Blue
    2x 10" IDMax D4
    1250.1 kicker amp
    crappy dell carputer
  5. #45
    Mar 2005
    Hi all!
    Im just fixing up my ol ipaq 3660 with new batteries at the moment... Does anyone have a working IPAQ-PC vnc connection going like <Question> at the moment via usb/serial? The reason i need this i cause i dont have any BT/WiFi on my IPAQ.
    Hope to see sone good news here!
  6. #46
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    You might want to give this a go.
    http://www.pdawin.com/
  7. #47
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Quote Originally Posted by Magnezium
    Bluetooth:
    VNC:
    I'm using a direct connection through the serial port. The VNC connection really has nothing to do with the network in my case. You don't any type of network connection.
    However, I could see problems arising if you used bluetooth...but since this isn't my case, I have no idea.
  8. #48
    Newbie pROJEKT vw zWO's Avatar
    Mar 2005
    South Africa
    MITE I SUGGEST BEMUSED (BEMUSED.COM) it works with winamp but im trying 2 get it working woth frodoplayer if it can b used. it works well with sony ericson p800 & MS powerpoint
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
    I dunno why but it just worx sumhow
  9. #49
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    thats the programs like this one:
    http://www.remotelyanywhere.com/temp...12#screenshote
    work with ad-hoc or only let say AP to usb network adpater,I just don't feel like having a AP in my car(to many things in the car already)
    P.S: to Magnezium:
    Did you finally make that soft and are you releasing it or you looking to make profit out it......
  10. #50
    Jan 2001
    Austin, TX
    eww...so I had tested my palm with my computer while connected to my network...I finally put the computer in the car and realized it won't work since there is no network to assign an ip address to the computer. I can't even set one manually since winxp says "Media disconnected"
    ...so this may have derailed the vnc effort, unless someone can tell me a good way to trick windows into giving itself an ip address without being connected to anything. (or wiring up some kind of trick cable...) Any ideas?
