Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 72
Thread: PDA for remote
  1. #51
    Newbie pROJEKT vw zWO's Avatar
    Mar 2005
    South Africa
    heres some help with vnc when u connect it works with my p800
    The secret was the loopback setting in the registry. On my PC the setting is called "AllowLoopback", it's set to DWORD 1 and it is at HKEY_LOCAL_MACHINE\\SOFTWARE\\ORL\\WinVNC3.
    vnc is gud but a bit slow thru blueteeth, i found bemused.com much better though, i wanna know if any1 has tried bemused yet? how can we intergrate it to frodo player
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
    I dunno why but it just worx sumhow
  2. #52
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Quote Originally Posted by pROJEKT vw zWO
    WTF? Dude, take your awful spelling and click trolls somewhere else.
  3. #53
    Mar 2005
    South Africa
    Quote Originally Posted by rubicon
    Sorry 4 da bad ingleesh its do way we talk here in SA but il try & transl8 4 those who dont play with shorthand dictionaries & prefer 2 waste bandwidth with extra keystrokes
    translates to:
    WinVNC is good but a bit slow thru bluetooth.i found on bemused.com (the only thing there is bemused) much better though than vnc, i wanna know if any1 has tried bemused (this program)yet? how can we intergrate it to frodo player I think the rest is simple enuff 2 understand sorry if i offended ne1
    Carputer status:
    {=======---}70%
    Install status:
    {======----}60%
    Software status:
    {====------}40%
  4. #54
    Mar 2005
    Quote Originally Posted by Question
    eww...so I had tested my palm with my computer while connected to my network...I finally put the computer in the car and realized it won't work since there is no network to assign an ip address to the computer. I can't even set one manually since winxp says "Media disconnected"
    ...so this may have derailed the vnc effort, unless someone can tell me a good way to trick windows into giving itself an ip address without being connected to anything. (or wiring up some kind of trick cable...) Any ideas?
    You should be able to edit the ip address with the network disconnected. And set up a network protocol for peer to peer. It should let you set the pc up as host. I'm pretty sure you can do it all in the wireless network setup wizard too. Just assign it an IP manually. I'm playing with it now, and I can set up all this stuff in xp while i'm not connected to a network.
    Dave
  5. #55
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Quote Originally Posted by Mick
    Has no one here even heard of DHCP Server software before?
    Microsoft did not include a DHCP Server in most of its latest operating systems for a simple reason: no one would need to buy their expensive Backoffice junk.
    Very easy to rectify with a nice free third party DHCP server that runs as a windows XP service.
    Here is a little screen shot of the AIVMS Lite PPC Remote, can anyone guess what it happens to be controlling?
    I assume you're using this for PocketPC?
  6. #56
    Feb 2005
    Your remote-controlled, ah, "personal massager?"
  7. #57
    Mar 2005
    A company called NoviiRemote (http://www.noviiremote.com) offers quite inexpensive software ($15 - $20 USD) that allows you to turn any old Palm or WinCE device into a highly customizable universal remote control.
    You can customize the user interface for each virtual remote control.
    It can also be run from an SD expansion card or a Memory Stick - works on PalmOS and WinCE/PocketPC.
    This is an IR solution, and not as robust as some others that have been mentioned, but perhaps worth a look. I tried it and it worked great on all of my household devices.
  8. #58
    Jan 2001
    Austin, TX
    Quote Originally Posted by dave2
    Dave
    ...played with it for about 30 mins before giving up. Could you tell me exactly how you did this? Whenever I tried to make a new connection (then chose Direct connection and set the computer as the host), it wouldn't allow mochappp to run, and still also wouldn't give itself an ip address.
    Are you using a palm or pocketpc?
    I still think physically tricking the computer into thinking it's plugged in would work..anyone have any ideas on how to wire an ethernet cable to do so?
    ...another cool old app is palmamp, which I'm playing with...unfortunately it crashes every time you try to exit it (but hey, it still works..) ...something about a null pointer (specifically an unlocked chunk of memory was allocated with memhandlenew but not locked with memhandlelock...or was locked then unlocked...but I don't have access to the source files to the palmamp apps...so I can't play with it, I don't think. If anyone has the source files for this or happens to program in the Palm OS, let me know).
    ...would be sweet if palmamp didn't crash.
  9. #59
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Quote Originally Posted by bcw55
    This would be good for "household" devices but I thinks some of us are looking to control front-ends and other app that are link to it.
    Thanks anyway.......
  10. #60
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    You could try PTVNC... It is like pcanywhere!!!
    It is very helpfull, especially when used by wifi!!
