Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Elo toucscreen Intelli touch
  1. #11
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Its easy man. Heres the pinout LONG POST AHEAD!!
    The ELO touchoverlay setup
    At the ELO controller P2 I used sockets I found at my job. The socket fit neatly onto the pins, once I had them all lined up and straight I used "RTV" wich is a type of silicon. But either HOT glue or normal silicon will work just fine. Just make sure NON of the pins short to another, cause will get all type of errors, nothing will get damaged, but it just sont work. I used 22gauge wire to wire it to the serial connector.
    P2 on the above image is the NINE wire serial connector. All you need to do is match up the numbers and you will be set.
    The PC's serial connector, this small image is LOOKING at the connector from the front.
    P4 is used for power. Connect P1 to your 12v rail of the psu. P2 and P4 go the black wire from the PSU connector. P8 Make sure you connect this to the chassis of the controller and ground it out. I had some major problems at first loosing my touch overlay. It would stop working, then connected this to the chassis of the controller and I have NOT had any more problems. I did NOT connect any other connectors, cause You really dont need the other features. There is a LED onboard the controller. P5 is for a remote LED. You'll be fine without connecting it. P9 is to reset the touchoverlay, again you will be fine without it.
    P3 is the one that connects to the Touch Overlay. No need to do anything here.
    Hope it works out.
  2. #12
    Jul 2003
    Earth
    oh wow i was expecting a rough guide!!! i didnt expect you to lay it before my feet!!!
    thank you very very much
    Im at work all week so im going on the scavenge to make the cables i was thinking you know those plugs you get to attach to motherboard pins for stuff like LED's and speakers....... they might make an adhoc plug.......
    15 GBP seems a bit steep for wire and plugs.....
  3. #13
    Feb 2003
    South Florida
    Just want to help out.
    Hopefully this post will help others as well. I dont plan on making this type of post again LOL.
  4. #14
    Jul 2003
    Earth
    Im in process of making them up now......ill post the results
