Results 1 to 10 of 16
Thread: Computer as the remote??
    Jun 2003
    Memphis - TN
    Heres a question. Most people put an IR reciever on the PC and use a remote to send a signal. What If I wanted the PC to send the signal to my headunit? That way I can use PC controls to change inputs, control my radio ect, instead of using a separate remote.
    Basically use a program to scan a signal, and assign it to a button to control the radio. Like source, mute, ect.
    Ideas? Comments?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Custommx3
    Ideas? Comments?
    you need an ir emitter, there are several ready made ones, lemme see what I can dig up
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2003
    Memphis - TN
    http://home.earthlink.net/~jrhees/USBUIRT/overview.htm
    this seems to be a solution, BUT I dunno how I would integrate that into an application.
    Dec 2002
    Illinois
    i was gonna use this to control my headunit with the backseat controls of my explorer it could probably be modded to work with a serial port or some relays
    http://www.crutchfield.com/cgi-bin/S...7SWIX&g=118900
    Jun 2003
    Aug 2004
    Germany
    Updates un this topic realy need that kinda thing too
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    Dec 2004
    CT
    Im sure it is possible, like the others said, you can ether buy a unit to send and recive IR signals, or you could build one. Like you said you can train grider to recive a signal from your remote that came with the HU and duplicate that signal for transmitting back to the head unit. havent really messed around with it yet but im sure it can be done
    Aug 2004
    Germany
    im sure it can be done but i want to se a circuit or sth to buy
    Golf 3 CarPc Status
    PSU:Inverter
    GPS:BT GPS
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Erazor, I built one of the original serial UIRT's a few years ago and have had it working very well as a reciever since but have never got round to testing the emitters as i just use the all-in-one remote i use for my PC to do everything.
    There is a newer version than mine but i didnt keep up with the design as mine hs worked fine. Will dig up some info when i get home from work if the info is no longer on the internet (don't think the UIRT link above has info for DIY)
    Mar 2004
    Bristol
    Just thinking after seeign a link off the page posted by -B-e-n- (http://winlirc.sourceforge.net/controlbywire.html) that maybe you could simply miss out the IR emitters and remove the reciever from your device and wire direct up to save having to loacte an IR transmitter anywhere.
    Or it might be better to remotly mount your device reciver in a box with your emitters pointing direct at it. might make it more reliable - especially in sunlight.
    Other way would be to use a relay board and hook it directly to the tactile switches in your stereo - not really a hard job if you have a nice small soldering iron.
