Page 1 of 6 123456 LastLast
Results 1 to 10 of 58
Thread: Night Vision (IR) cameras
    Jul 2003
    So Oregon
    Has anyone looked into IR cameras for a car PC? Im not sure how usefull it would be. But has a definate cool factor.
    I thought of this last night while my friends were street racing (on a safe road, not in the city). If cops came, I could have drove with my lights off on dirt roads and hit the highway a mile away Spectator tickets are $400 .
    But I'm not planning to drive around with my lights off at night or anything. If I did use it in the previous situation I would be cruising at 5-10mph, but that was just more of a weird fantasy than anything.
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Old QuickCam's (and probably a lot of other CCD based cameras) have an infrared filter in front or behind the lens. If you remove this filter, you can make an infrared sensitive webcam.
    The thing about IR cameras is that you'll actually need something that's reflecting IR to look at. This is not so much a problem outdoors in the daytie, but at night, you'd have to mount some IR "headlights" on your car to have something to see!
    Also, if there is any visible light and you have the IR filter removed, the AGC in the camera will overload and the picture will white-out. The ideal thing to do is to replace the IR filter with a visible light filter (that passes IR) -- you can probably rob one of these from a broken remote control, and you are done!
    What's cooler than IR though are combined IR+Thermal imaging sensors.. But those are hella expensive devices!
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    I have been looking at different suppliers for FLIR (Forward looking IR with thermal imaging) the same ones that Police Agencies use. They run about 1500 just for the camera. However, I recall Caddies that came with IR HUD. How about ripping a IR module out of that and putting the image on the LCDs we already have? I assume there should be one of two of those caddies in junkyards.
    L
    EDIT: Currently my 3Com HomeConnect Pro webcam can take images in absolute darkness. Don't ask me how it is done but it's truely amazing. It's discontinued though. The only trouble I have is that when it is hooked up as a cam, your fps drops down if I have to do 800x600 image since it's USB. If it was firewire, it would be amazing.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    What about using the old sony handi cams that have night shot? If I remember correctly those did the job quite well. They also had the interesting quirk of being able to see though some peoples clothing in the daytime.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Jun 2003
    Elmhurst, Illinois
    Quote Originally Posted by fluffy2097
    Those things are fun. Not great but fun. They are also no longer made.
    L
    - Lwin M. Maung
    Aug 2003
    Orange County, NY
    Not that I aprove of this stuff... but if you install IR "Headlights" or illumination on your vehical to drive at night... Most police cars in NY are setup with video cameras and recorders which will detect "see" the IR light source. Just try pointing a remote control at a most CCD video cameras and see what happens. You'll see a white spot on the image.
    Just trying to throw out thoughts...
    Good luck with it!
    Jun 2003
    Elmhurst, Illinois
    I do not approve of street racing either but FLIR is nice if you are driving in the middle of nowhere and a bambi decides to cross the road in complete darkness since you can see bambi on your screen.
    - Lwin M. Maung
    Aug 2003
    Amarillo, TX
    Not to mention you'd have to drive without pushing your brakes either. And, police also have ears and spotlights.. pretty dumb move to try to run from the police like that, but whatever.. I think it'd be neat to have a system similar to the cadillac's HUD, but really without a HUD it's pretty worthless..
    I wish there was more room behind my instrument cluster.. It'd be fairly straightforward to build an overhead-projector LCD panel into a HUD!
    MY CAR IS FOR SALE!
    Sep 2003
    Elgin, IL
    many of the CMOS B&W cameras are near-IR sensitive, but this means you need an IR illuminator (basically IR flashlight). the other side of the IR technology is the IR band camera. Alot of those need active cooling to make the thing work. Yea I'd try to see if there's a wrecked caddy and steal that
    Jul 2003
    So Oregon
    Like I said, escaping the police was just kind of a fantasy.. day dream. I dont watch them often and I only race at the track once a month.
    Those nightshots cameras were fun
    Maybe using a couple clusters of IR leds hidden behind the grill. Probably wouldnt put out much light though, and leds tend to put out lights in beams so the image would be spotty. But led's are cheap.
    Of course I would never use it in town. Unless I get built a circuit timed like a police/ambulance light .. then I would never have to wait at stoplights
    "cadillac night vision" in google images came up with some interesting pictures. I would have to see one of these in person. Looks cool.
    It uses a camera in the center of the grill and projector in the dash which projects a small image on the windshield.
    I wonder how much a wrecking yard would charge if I did happen to find one..
