well that Y splitter is feeding voltages both to your HU and shuttle pc when the PS2 is being used and its ALSO feeding voltage to the PS2 and HU when the shuttle pc is being used. That said you can damage the outputs of either component.
The problem you are encounting is the RCA outputs of your PS2 have a higher voltage output than your shuttle pc has. It can go either way.
The problem you are encoutering is your "Y" splitter. If you really want to get rid of the problem, you can get a mixer?!?!?! or even connect the PS2 to the inputs of your shuttle and use the shuttle for the audio of your PS2.
Its confusing and its gonna be a pain in the *** to fix.
The problem with your hissing comming from the shuttle is ground loop noise. Do a search this has been discussed millions of times. It can be alot of things.
LinkBack URL
About LinkBacks
