Results 1 to 6 of 6
Thread: Touch screen, wrong orientation...?
    Low Bitrate Vittel's Avatar
    Aug 2003
    England
    Installed the TouchScreen drivers, when trying to calibrate it always fails on the 3rd point - the touchscreen seems to think it is 'rotated' by 90 degrees - eg, press a point on the screen and the cursor appears, press to the RIGHT of that point and the cursor moves UP the screen. Or press a point on screen, then press another point BELOW and the cursor moves to the RIGHT. Basically the touchscreen needs 'rotating' 90 degrees in software - it will not calibrate and always fails on 3rd point, on 25 point too (I assume it is the rotation problem causing this)
    I noticed a utility called RotTray, but this seems to need 3rd party software (Pivot?) to function - any suggestions..? (Win98se, USB 7" touchscreen)
    Nehemiah M10000 board, 512Mb RAM, Win98'lite', 7" TFT DIN in-dash VGA touchscreen. IR keyboard. GPS.
    Aug 2003
    England
    Cheers for suggestion - tried what you said - removed mouse etc - uninstalled drivers - reinstalled drivers etc with exactly the same results :/
    I've just set it up on a totally separate machine and it is exactly the same grrrr - I feel like ramming a screwdriver through the f'king screen at the moment.
    Quote Originally Posted by bjm2020
    I did have the same problem as you. I even sent my screen back to digitalww thinking it was messed up. He looked at it and it worked with his pc. Do you have a mouse connected along with the touchscreen? That seemed to be my problem, i think. Try taking all of your peripherals off and trying one by one putting them back on. Thats what worked for me!
    Aug 2003
    England
    *bump*
    Armen - are you out there...?
    Aug 2005
    i have the same problem, i think...
    i just bought a 10.4" lilliput and initially i just thought it needed calibration, so i found the latest drivers and installed them, but when i go to calibrate the first point never stops flashing, so to see what was happening i thought i'd bring up that draw screen, and this is what happens
    if i draw from the centre to the left the screen thinks i'm drawing down
    to the right, it thinks i'm drawing up
    if i go up, it thinks i'm going right
    if i go down it thinks i'm going left
    so its not even just rotated 90 degrees the one direction? the axis are completely confused? i hope its software not hardware related!
    can anyone help?
    Elsewhere
    Press and hold the calibration point.
    And there's no need to resurrect a 2 year old thread with a different problem.
    How about the Wiki?
    Aug 2005
    as far as i can see it is the same problem, and as there wasn't an answer to this problem why start another thread for something thats probably the same problem? plus it shows that i ed
    but thanks for your response, i'll give it a shot now
