7" touch screen orientation
Hi.
I have 7" touchscreen from digitallww and have a little problem with the screen orientation.
The horizontal orientation is messed up, when i touch left side of the screen the cursor will move to the right side of the screen and vice versa. Vertical orientation is fine.
Does anyone have any idea what might be messed up?
TIA
I have exactly the same problem, I posted the problem but as yet no replies. I have found a work around for my problem, if you leave the screen plugged in then after calibration you should find the changes persist till you unplug the power once more.
If I find a resolution Ill be sure to tell you.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
