Results 1 to 4 of 4
Thread: Touchscreen hibernate help
    Jun 2003
    Atlanta/Augusta, GA
    I have a Xenarc 700TSV with serial touchscreen. I use a usb-to-serial adapter to connect the serial ts to the usb hub near the dash. When resuming from hibernate, the touchscreen does not work. If I launch the configure utility, after a short delay the ts starts working again.
    Any ideas on what the problem is or how to automatically get the touchscreen working after hibernate?
    Sep 2003
    dana point Ca
    I have that same problem does any one know whats up????
    Nov 2003
    Tampa, FL
    Reply this might help but not sure. Assuming its the same on any Windows if you have USB ports. (I have XP)
    Go to Control Panel-->System-->Device Manager
    Click on Universal Serial Bus Controllers and for example mine says:
    Generic USB Hub
    Intel (blah,blah,blah) Host controller 2442
    Intel (blah,blah,blah) Host controller 2444
    USB Root Hub
    USB Root Hub
    Click properties on the bottom two
    Click Power Management
    Uncheck Allow Computer to turn off this device to save power
    Might Work might not haven't really tested it but it seems plausible that would make the USB always powered.
    Sep 2003
    dana point Ca
    what if its not usb??the touch screen I use has a serial connecter.I tried what you said but it did not work. any other suggestions????
