Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: USB Extension problems
  1. #21
    Variable Bitrate slarty's Avatar
    Jan 2002
    United Kingdom
    supposidly over a certain length an active extension is required, I have forgotten the details and how it works I'm afraid but this is supposed to be all you need.
    Quote Originally Posted by LESLIEx317537
    What's a active extension cable?
    I used a 2.0 extension cable in my car. It was like 10 feet.
    Lilliput 8", C134 EPIA-M 900 (Black), A1-ITX, 256 Mb RAM, 40 Gb HDD, DVD, 802.11g, mini keyboard
  2. #22
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Quote Originally Posted by slarty
    I will try this
    Many thanks
    Well let me report that I was 0 for 4 the next day with this change. I still have to do the unplug/plug thing. I came accross this article about Windows XP:
    http://support.microsoft.com/default...b;en-us;810090
    SYMPTOMS
    You may experience one or more of the following symptoms on your Microsoft Windows XP Service Pack 1 (SP1) or Microsoft Windows 2000 Service Pack 3 (SP3)-based computer:
    Universal Serial Bus (USB) devices are not detected when you restart the computer.
    USB devices are not detected after you resume the computer from hibernation or standby.
    The computer uses 100 percent of the CPU time when you move the USB mouse.
    The computer stops responding (hangs) when you resume the computer from standby when a USB mouse is connected.
    The computer takes a long time to start or resume when a USB device is connected.
    A yellow exclamation point with a Code 28 or Code 31 is displayed on a USB device in Device Manager.
    USB 2.0 Hi-Speed devices are detected as Full-Speed (USB 1.1) devices when your computer resumes from hibernation even though they are plugged in to a USB 2.0-capable port.
    No link is provided to download the fix. I called and talked to MS customer services and because I have an OEM license they won't provide me with the fix. The article recommends waiting for XP SP2 so I'm going to try and find the beta on edonkey. I can't believe I wasted money buying a license and get treated this way by Microsoft-what a joke.
  3. #23
    Mar 2004
    Vancouver, BC, Canada
    I have the same problem with my Linksys Wireless G USB device not being recognized unless I unplug it, and plug it back in.
    I heard Windows XP SP2 is supposed to fix this, still need to try the beta. Linksys hasn't released any new drivers for the device.
  4. #24
    Jan 2004
    I have the same problem with the touch screen, i use 1x 5 m extension to a 4port usb hub (unpowered). Every now and then when i boot up, i have to unplug the touchscreen one and plug back in. It's bizzare but not a serious prob. It's good to see someone else has this prob and im not crazy!
    usb hub runs:
    - touchscreen
    - external usb dvd drive
    - gps thing
    - playstation controller convertor
    the dvd and touchscreen get their own power, power isnt' an issue. I can transfer files from DVD drive pretty fast. Haven't timed it but has no problem playing dvd movies.
    im running windows 98 SE btw
  5. #25
    Jan 2002
    United Kingdom
    Interesting on the MS front I was waiting for SP2 to see if that would resolve the issue. Temporarily I have just gone back to not using an extension cable.
    As you say nice to see that were not loosing it
    Quote Originally Posted by MerlinDaHapyPig
    usb hub runs:
    - touchscreen
    - gps thing
  6. #26
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Now this is happening to my powered hub in back ever since I put the Audigy 2NX and the Linksys G WiFi on it.
    Argh!
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  7. #27
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    I'm not even going to read the rest of this topic... It sounds to me like you people need to upgrade the drivers on your USB. I had the same problem for a while and thought it was board level (which was some what true). What you need to do is update your firmware on the board. If you do, the USB should work a lot better. In most cases, the USB root hub resets. It's a common misconception that the cable is bad (but not always wrong). Sometimes it can be the cable, but if you're getting signal and then it just stops, then it's probably board level or the cable might be kinked, stretched, or bent too hard.
    Mg.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  8. #28
    Jan 2002
    United Kingdom
    So its probably the driver, firmware or the board but might not be, or it could be the cable... thanks
  9. #29
    Mar 2004
    I tried Windows XP SP2 beta on the weekend and it fixed the problem with my Linksys 802.11g USB device needing to be unplugged, and reconnected to be recognized.
  10. #30
    Jan 2002
    Long Island, NY
    Windows XP SP2.
    Nice, I can't wait. Whens XP SP89 coming out?
  1. usb mouse stops working
    By corsamel in forum General Hardware Discussion
    Last Post: 10-18-2003, 05:53 AM
  2. GPS Receiver - USB -vs- Serial
    By Daz in forum GPS
    Last Post: 06-24-2003, 04:56 PM
  3. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  4. USB extension
    By az1324 in forum General Hardware Discussion
    Last Post: 12-15-2002, 11:14 AM
  5. longest usb extension
    By zx3chris in forum General Hardware Discussion
    Last Post: 09-30-2002, 01:39 AM
