Results 1 to 5 of 5
Thread: Datalux TS problems
    Banned NightHunter's Avatar
    Dec 2003
    Milwaukee, WI
    Datalux TS problems
    Does anyone else have the problem with there Touchscreen.
    When I press on the screen to select something, It clicks first on the last thing I clicked then I have to touch the screen again and then it works.
    Any Ideas how to fix this.
    I am using the Datalux TS lmv10r Resistive Touch
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    quit playing with your touchscreen like that... you could get arrested for molestion... Tisk Tisk
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
    Nov 2003
    Touchscreen Problems
    I think resistive touchscreens have two layers of conductive material seperated by tiny insulators . When you press on the top layer, the material in between makes contact and allows the position to be registered. It may be that the layers are sticking after being tapped and that you need to tap that area again for it to get unstuck. I know a lot of people have problems with temperature screwing up the calibration or causing the touchscreen to act erraticly.
    Dec 2003
    Milwaukee, WI
    More specifically what happens is, I click one icon, and if I go to click a different one, I have to click it twice, but the fist time I do It clicks on the previous position again. It will do this no matter the temp, I can be driving all day the same results.
    Dec 2003
    Milwaukee, WI
    Figured out the problem. I deserve a smack in the head for this. Under settingsin the setup menu, there is a slide bar that is labeled click. I guess this means amount of time you have to hold your finger down in order for it to register, not quite seconds but set at 3 I had to hold my finger down for about 1 second. Wierd. Well it was set to 3 out of a possible 19, I reset it to zero. No more problem. Instant registering, works great now.
  1. Replies: 21
    Last Post: 06-04-2005, 04:44 AM
  2. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
  3. What panel does datalux 10.4" have?
    By kickercivic1 in forum LCD/Display
    Last Post: 02-04-2004, 01:56 PM
  4. Datalux LCD replacement (Goldstar)
    By Cordell in forum LCD/Display
    Last Post: 07-24-2003, 07:39 PM
  5. DataLux and LCDs in general
    By perseus98 in forum LCD/Display
    Last Post: 03-12-2002, 10:28 AM
