Results 1 to 10 of 10
Thread: TV Tuner
    Jan 2004
    TV Tuner
    Any chance I could somehow use my TV Tuner card and a mobil TV antenna to recieve and watch local tv on my pc??? If not, let me know how it would work.
    Thanks,
    Landon
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    you could do that.. you won't get reception while driving though. Most tv tuners have a setting to switch for broadcast or cable.
    '98 Explorer Sport
    80% done
    Jan 2004
    Why would there be no reception while driving??
    May 2002
    Albany, NY
    you need a special antena that is like the size or a car's roof in order to get reception. The reason is that broadcast TV was not designed like radio. Meaning that it was not designed to be picked up while moving. I had pretty good antenas on my truck and i could pick up sound just fine but no video.. it was hardly viewable.
    '98 Explorer Sport
    80% done
    Sep 2003
    I will have to throw my 2 cents in. I had a little portable 7 ich B&W tv that i used to throw in the back of my truck before installing a multimedia system. I used to get pretty good reception on the same channels i would get normaly. didnt make a difference if i was driving or not. I have yet to hook anything up to my TV tuner card but if a little portable tv can pick it up i dont see why a tv tuner card with a good antenna couldnt.
    May 2003
    MA
    Quote Originally Posted by Xanadu1979
    Thanks,
    Landon
    I got a WinTV card in mine, all I use for an antenna is a old TV antenna the kind that sits on top. I'm planing on getting a amplified mobile antenna that sticks to the inside of the rear window. As for reseption, if you live in a city you will get the local channels... the quality is actualy good in the Boston area.
    Low Bitrate BrUTaL's Avatar
    Dec 2003
    Guayaquil - Ecuador
    If you want to watch TV while driving, you should get this:
    http://www.detnews.com/2004/autoscon.../g03-35101.htm
    And I can you tell what is a good tv antenna for my car....where can I get one?
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Try hooking you car's radio antenna to the TV card. Worked for me.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Dec 2003
    Guayaquil - Ecuador
    If I do that, how is the image quality of the TV while driving. I know I won't be watching TV while driving, but the passengers might. I haven't check what type of input the car radio antenna have, can you tell me how I should hook the car's radio antenna to the TV card? What type of adapater should I get?
    Feb 2001
    Quote Originally Posted by BrUTaL
    Depends on how strong the channels are. Weak channels might fade in and out while driving (55+ mph).
    Find some cheap rabbit ears and place them in the back window, see how well of a single you get.
    Technically, antennas are tuned to frequencies. The higher the frequency, the shorter antenna is required. TV is VHF-lo (55.25-83.25Mhz), VHF-hi (175.25-211.25Mhz) and UHF (471.25-801.25Mhz), FM (88.1-107.9Mhz) is between VHF-lo and VHF-hi.
    http://hotspotcb.com/cbshop/techtips/ANTtool.html
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
  1. TV Tuner Cards
    By inmytree in forum General Hardware Discussion
    Last Post: 04-23-2004, 06:35 AM
  2. 10.4" LCD monitor w/ TV tuner $260 Shipped NEW
    By CDesigns in forum Classified Archive
    Last Post: 12-06-2003, 06:14 PM
  3. What TV tuner card are you using to record TV shows?
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-23-2003, 11:44 PM
  4. anyone know of any tv tuner software?
    By e36mp3 in forum Software & Software Development
    Last Post: 05-31-2002, 04:46 PM
  5. What to do for TV tuner?
    By Adam F in forum General Hardware Discussion
    Last Post: 06-01-2001, 06:52 PM
