Page 17 of 26 FirstFirst ... 7891011121314151617181920212223242526 LastLast
Results 161 to 170 of 260
Thread: sony "joystick" commander.
  1. #161
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    If I understood Gore's problem, he needs a "release" event on the plugin so that the unit sends "0.0.0.0" when the button is pressed... is that implemented and simply not working on his side, or just not part of the plugin?
    -Mars
  2. #162
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Sorry, I was on vacation for a week. Download it again. I've got a "0:0:0:0" in there now. I had the logic in there, but not really implemented. I don't exactly understand girder too much so try it and let me know if that's right. I could also change that to something like the last value released like:
    "-50:0:0:0" - press
    "-50:0:0:1" - repeat
    "-50:0:0:2" - release
    Would that be better or worse?
  3. #163
    Low Bitrate Gore-'s Avatar
    France
    it can be better I think
    or can made the choice in config :
    - return to "0" on release
    - send a release ":2" event
    very good job
  4. #164
    So for this thing, it plugs into the game port and in order for it to work with a usb converter, you have to add a resistor?
    Since I suck at soildering, how much would one of you charge to modify one?
  5. #165
    Mar 2004
    Florence Yall, BFKY
    Heezzi, you will need 2 120K resistors either way. Connecting those between 5V and the X and Y input (even without the sony stick) will supply somewhere around 2.5V to X and Y and act as a basic joystick to make the windows driver see a valid 2 axis joystick connected and centered (sort of) so it will load. Then with the sony stick connected and a button pressed it's like the 120K + another resistor in parallel lowering the resistance (each button is a different value and no press = open or 120K).
    Soldering is learned through practice. Do it 100 times and you'll be good at it. I really think this is an important skill to have if you're going to be around here!
  6. #166
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    Finally finished reading the whole thread! (ie, skimmed it... )
    I'm quite interested in this myself, although my electronics skills amount mostly to changing the odd fuse on a mains plug...
  7. #167
    Feb 2004
    Montreal
    if you can use an iron, you can do this.
    -Mars
  8. #168
    Has anyone interfaced it with an Ir port?
  9. #169
    Jun 2004
    frodo - sony remote - grider gml, please.
    Hello
    can someone post the frodo - sony remote rm-x4s - grider gml?!
    I have already the plugin for the sony remote and Im about to use the gml that frodo post but the command keys arn't memorized.
    Tanks
    Alex.
  10. #170
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by Alex Pt
    Hello
    Tanks
    Alex.
    Afraid that even if we post our own gml it wont help you. I used the gml that frodo posted and added the commands. The values that the sony joystick returns change acording to the way you set up the plugin. It's very simple, you just have to expand the relevant command, press the learn button and the just press the correct button on the sony.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  1. Sony UniLink protocol explained here, can someone?
    By SuperSonic in forum General Hardware Discussion
    Last Post: 06-28-2005, 12:37 PM
  2. Would anyone buy CD Changer/Unilink cable hacks for Sony head units?
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 06-14-2004, 03:55 PM
  3. Replies: 6
    Last Post: 10-19-2002, 12:18 PM
  4. Use my touch screen to control my SONY head unit
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-14-2002, 10:37 AM
  5. How do I get sound into my Sony CDX-M700R?
    By percyt2k in forum General Hardware Discussion
    Last Post: 06-05-2001, 11:17 AM
