Page 18 of 26 FirstFirst ... 891011121314151617181920212223242526 LastLast
Results 171 to 180 of 260
Thread: sony "joystick" commander.
  1. #171
    Jun 2004
    but frodo gml doesn't have the shortcuts (ctr+z, ctrl m, etc...) in the file, just the groups created.
    I know that I would have to memorize the "events", but it would be easier.
    thanks
  2. #172
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by Alex Pt
    thanks
    Its easier. Frodo file doesnīt use keyboard shortcuts, it uses windows messages witch the monkey already put in the file for us. All you have to do is memorize the correct events for each command and it should work perfectly.
    P.S. Make sure you have the SendMessage plugin activated in Girder Settings.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  3. #173
    Jun 2004
    hahh
    so that's the reason...
    I didnīt have the plugin activated.
    thanks again
  4. #174
    Low Bitrate Gore-'s Avatar
    France
    Hello
    I'm back after a lot of problems on my carPC... now it works 90%
    I'm always bad in english but I will try to explain my problem with the last version of your great plugin :
    First problem
    When a release a button, the code return to 0:0:0:0 (good )
    but if a push the same button, it don't woks...
    I must push another Button (assigned or not) before retry the first one
    Second problem :
    With repeat delay enabled, the repeat command is send correctly,
    but when a release the code stay (-120:0:0:1 for example). (but no signal sended )
    Thank you your patience and your courage
  5. #175
    Constant Bitrate cbergeron's Avatar
    I can provide you guys with a serial port circuit that will interface with the rm2xs and rm4xs. We had a Via Epia, no gameport, so we created a serial port circuit to convert it.
    PM me if interested.
    Kind regards,
    CB
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
  6. #176
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Gore- download it again and give it a try. I think I missed a variable reset.
    I was using a joystick the last time to test it which never returns to the same value (simulating a button press is hard that way).
    cbergeron would that work with other resistance values? Like maybe 500 ohms, 1.6K or 13K? You just might have a market for those!
  7. #177
    France
    waouh ! :|
    Faster is impossible lol
    I try at once
    EDIT :
    WAOUH !!!
    PERFECT !!
    Nice ultra fast job
    tanks a lot, i'm Impressed
  8. #178
    France
    Ooops
    When I launch Girder X2S send 1:0:0:1 (and repeat)
    When I press a button it stop and the plugin works perfectly
    Sorry
  9. #179
    Mar 2004
    Florence Yall, BFKY
    Oh so close! What are your deadzone values set to? Try 1 in the bottom left (X max). That should keep it from doing that.
  10. #180
    France
    it's set to -5
    EDIT :
    It works fine you're the best !
    I work on it to learn all events
  1. Sony UniLink protocol explained here, can someone?
    By SuperSonic in forum General Hardware Discussion
    Last Post: 06-28-2005, 11:37 AM
  2. Would anyone buy CD Changer/Unilink cable hacks for Sony head units?
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 06-14-2004, 02:55 PM
  3. Replies: 6
    Last Post: 10-19-2002, 11:18 AM
  4. Use my touch screen to control my SONY head unit
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-14-2002, 09:37 AM
  5. How do I get sound into my Sony CDX-M700R?
    By percyt2k in forum General Hardware Discussion
    Last Post: 06-05-2001, 10:17 AM
