Page 2 of 26 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 260
Thread: sony "joystick" commander.
  1. #11
    Mar 2004
    Norway
    I have an old Sony head unit called XR-C500 , and it has a remote that looks just like the one on this link http://llg.cubic.org/tools/sonyrm/
    Are there different versions of this kind of looking remote, or is it just one of a kind? Does it work with windows?
  2. #12
    Mar 2004
    Newport, Gwent, S.Wales UK
    I have been wanting to do the same thing for a while myself. I am using windows XP and do not have a game port on my MII1000 board. Anyone got any ideas?
  3. #13
    Newbie jics's Avatar
    Sep 1999
    Source for interfacinf RX-X4S
    Hi,
    I've coded a interface to a RM-X4S some time ago. The code is for linux, but it may give you some inspiration on how to handle this device under windows.
    In any case you will need to implement some kind of calibration programm, as the resistor values change slightly after some usage. (They also seem to depend a little bit on the temperature in the car)
    hope it helps...
    PS #1.: I had to rename the files to .txt to be able to attach them.
    PS #2.: Why is this attachment-feature not working under mozilla ?
    Attached Files Attached Files
    ...Unix, DOS, and Windows XP
    (also known as the Good, the Bad, and the Ugly).
  4. #14
    Newbie dansoton's Avatar
    May 2003
    Southampton
    Quote Originally Posted by jics
    Hi,
    hope it helps...
    Thanks jics, much appreciated. Interesting what you say about calibration, I wonder how the head units deal with this? Also how did you interface the joystick with the PC, using the game port? Just I'll have to interface it with the serial port as I've got a M10000N board which doesn't have a gameport.
    If anyone has any ideas about interfacing it with a serial port, it would be much appreciated. Cheers guys.
  5. #15
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    according to jics's post, the variable resistor myth is proven to be real.
    I plan on simply using girder to control the game controller simulated by this joystick (and a proper interface), it should be relatively easy.
    there are guys at girder that are developping the analog joystick support for it. Its pretty sweet.
    Windows would then include you calibration
    I still have to transform my RM-X1S into an X2S or X4S compliant... anyone have the resistor values?
    thanks.
    -Mars
  6. #16
    Sep 1999
    Detail on RM-X4S
    Hi,
    To dansoton: Yes it is connected to a game port. You cannot connect it directly to a serial or parallel port. If you want to go this route, you must use some kind of microcontroller or PLC with a Analog input. The alternative would be an USB A/D-Cenverter ( ).
    To Marsupial: The bare resistor values would'nt help you much, as they differ slightly from device to device. It seems to me that the Sony headunits do some kind of callibration too.
    regards,
    jics
  7. #17
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    This is all very interesting, I have one of these controllers, not sure which model it is as I bought it about 6-7 years ago.
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
  8. #18
    Sep 2003
    UK, Sale, Cheshire
    One more thing, my carpc has no game port, but I do have a USB gameport adaptor from a TRUST wireless sightfighter, any chance that this might work?
    Craig
    Audi S8 supercar
    Toyota Hiace Van
  9. #19
    Feb 2004
    Montreal
    craig, I don't know about taking the program it yourself route, but with the girder joystick plugin, it detects any game controller you have, even USB ones. Therefore if you have a USB gameport and interface the sony unit to mimmic a joystick, you're set.
    I didn't try it yet with a real one, but I tested it with resistors and it is working, you just have to program girder to make your PC do whatever you need with it.
    give a look at
    http://www.girder.nl/phpBB2/viewtopi...=4867&start=30
    and
    http://www.girder.nl/phpBB2/viewtopi...&highlight=x1s
    -Mars
  10. #20
    May 2003
    Southampton
    Thanks jics, i'm on the case...
  1. Sony UniLink protocol explained here, can someone?
    By SuperSonic in forum General Hardware Discussion
    Last Post: 06-28-2005, 11:37 AM
  2. Would anyone buy CD Changer/Unilink cable hacks for Sony head units?
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 06-14-2004, 02:55 PM
  3. Replies: 6
    Last Post: 10-19-2002, 11:18 AM
  4. Use my touch screen to control my SONY head unit
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-14-2002, 09:37 AM
  5. How do I get sound into my Sony CDX-M700R?
    By percyt2k in forum General Hardware Discussion
    Last Post: 06-05-2001, 10:17 AM
