Page 25 of 26 FirstFirst ... 151617181920212223242526 LastLast
Results 241 to 250 of 260
Thread: sony "joystick" commander.
  1. #241
    Jun 2004
    I suspected that. It's almost the time -99 and doesn't change. If I set it to min=-99 and max=0 or 1, there's no response.
    I think I only gut a response when the dead zone is set to the buttons values.
    Out of the dead zone thereís no action signal.
    When it was working, I had to set the dead zone to max=7 or 15... In order to put it working, but the centre value was -99 or 0..!!
    I have to get another gamepad to be sure that is not that the problem!
    But itís strange, since I get all the values in the plugin, but they donít show in the girder window.
    What should I do?!
    Alex R
  2. #242
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Hey Alex, it may be where you are setting the min/max. When using the Y axis, the 2nd set are used even though it doesn't really show an X or Y anywhere. Just uncheck the X, so all the X values are ignored and use that middle column for the deadzone.
  3. #243
    Jun 2004
    Hello Curiosity,
    Yes, itís what Iím doing. The x axis is unchecked because itís unusable (it doesnít have any load, so the values keep changing).
    Iíve tried all. Now I have Poll rate = 33ms; Range = 100; Threshold = 1.
    Itís the latest JoyAxis Plugin and girder 3.3.7
    Iíve had it working on another computer, but maybe it was with girder 3.3.4.
    Iīm going to try with the old version, but it's strange!
    Tanks!
  4. #244
    MySQL Error
    Oct 2004
    FYI, see what im doing here
    had nothing to do with carpc's at first...
    but i think these are the most pratical controls for audio in a car
    no way a IR remote while moving
    sony's sticks rock!
    SONY RMX5s / RMX6s to RS232 (and rmx4s/x2s)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #245
    Jun 2004
    Yes mitchjs, Iím also interested in the rm-x5/6s, but the game port has the buttons, that Iíll use for 12v sense. Iíve already rebuild it so I can connect it to a light sensor, panel buttons, door, cell phone kit (if Iíll have one), etc. (I have a 15 pin connector and a 3,5mm in it.
    It also can be used with steering wheels (and at the same time).
    It also just needs usb, and I have it in the front for the touch screen (that was stolen a month agoÖ). In your version we need another cable (serial) to the front for the circuit & ir receiver or it could be used with a 3 wire extension (for the remote), or better (but more expensive) with a serial-usb adaptor.
    I will, however, Iíll want to try that rm-x5/6s, because as I told you in your post, the rm-x6s is really cool and practical to use.
    Please tell-me when you have a final version.
    If I donít find a way to my problem, Iím going to try both adaptors.
    Thanks.
  6. #246
    Jun 2004
    Ok, i've discovered the problem!
    The thing is that i can not calibrate the gamepad in windows!
    That way it takes the predefenitions and it works ok.
    If I calibrate it with the rm-x4s, the plugin won't send nothing to girder (only button press of gamepad, or the zero (0:0:0:0 if the dead zone is big enough to get a button value.
  7. #247
    Oct 2005
    I have finished wireing my sony commander with 2X 120KO resistors, but still no work. With a generic gameport--->USB adpter, windows will not recognize a joystick, and can not add it manually. With an adpter made by radioshack, windows recognizes the usb adpter, but I get the same values for any button pressed in the winamp plugin. please help....
  8. #248
    Mar 2004
    Florence Yall, BFKY
    Try calibrating it
  9. #249
    Mar 2004
    okay guys any HOW-TO? how much does this joystick cost?
  10. #250
    Jun 2004
    Iīve done it with a cheap usg gamepad with dual analog sticks and 10 buttons.
    itīs 15Ä. I've used 2 x 5k (4,7khom) in place of the y axis. The variable resistor that was there was 10k (like in the one I had before..).
    Still, I have 2 buttons of the sony joystick with the same value, but it might be a from the buttons not working well (or not!).
    But dont know why now I can't calibrate it like before, and have to use the predefinition.
    I still don't have a screen so, didn't test it in the car, yet.
  1. Sony UniLink protocol explained here, can someone?
    By SuperSonic in forum General Hardware Discussion
    Last Post: 06-28-2005, 12:37 PM
  2. Would anyone buy CD Changer/Unilink cable hacks for Sony head units?
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 06-14-2004, 03:55 PM
  3. Replies: 6
    Last Post: 10-19-2002, 12:18 PM
  4. Use my touch screen to control my SONY head unit
    By cproaudio in forum General Hardware Discussion
    Last Post: 10-14-2002, 10:37 AM
  5. How do I get sound into my Sony CDX-M700R?
    By percyt2k in forum General Hardware Discussion
    Last Post: 06-05-2001, 11:17 AM
