Results 1 to 10 of 16
Thread: Input Devicefor Winamp
    Feb 2004
    Hi,
    I'm trying to complete project of Jukebox with PC inside working with Winamp, Standard LCD and Keyboard input.
    I'm searching for Winamp opening file according to a button switched, for example, if i want "Let it Be" i have to press 1, if i want "tutti frutti", i have to press 2, and that way for 50 Songs (means that i have to press 1 and 0 for son number ten).
    Please help me because i have no solution, or it's possible to try other playing software.
    Oliver (from France, sorry for so poor English)
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Sounds like a job for a small VB app to me...
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    checkout and learn www.girder.nl I'm pretty sure it can handle it, right defiler?
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    Oliver.
    If I get it right, you want pushbuttons to interact with winamp.
    you can relatively easily interface 15 buttons/comport to winamp
    try this guide
    http://www.modasylum.com/guides.php?guide=21
    note: if you have hard times in english, PM me. I'm from Québec and always willing to write in french.
    -Mars
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I had a Winamp plugin which did EXACTLY what you wanted, waaay back when I had V1 of my Carputer...
    Basically, all you needed was the numpad from a keyboard, and you could control everything. Press 8/2 for volume, 7/9 for searching through the track by 5 seconds, 1/3 for skipping 10 tracks at a time, 4/6 for prev/next track, 5 for play/pause, 0 for stop, - for shuffle on/off, and then use + then type the playlist number, then + again for it to change to that song, ie +628+
    I'll see if I can dig it up...it also is used to control a HD44780 based character LCD, if i remember correctly!
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Aug 2003
    Essex, England
    OK, can't remember if this is actually it...but this seems to ring a bell...
    Lorty's mp3Car plugin
    Garry
    www.aimee.cc
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by jol
    Damn staight!!!
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Feb 2004
    Reply for winamp commands
    Quote Originally Posted by Confused
    Garry
    You seems to understand what i need, but the problem is that i want to choose by entering a "code" , for example to have the fifth song i want to push 5, for the ten's one i want to press 1 and 0.
    This is for being in the same configuration as olds jukebox where you choose your song on a panel.
    I can use other software if you know one working with LCD HD...., let me know
    Thanks in advance
    Regards
    Olivier
    Aug 2003
    Essex, England
    From that..I reckon you're gonna either have to:
    Find a Winamp plugin that does that (proved not so successful)
    Write a Winamp plugin that does that
    Write a program which can take the input from a numpad and push that to Winamp.
    Panic!
    Good luck!!
    Garry
    www.aimee.cc
    Nov 2003
    Detroit MI
    There is a plugin for Winamp that will let you choose a track based on its position in a playlist. The downside is that you will have to have a printout of the list with you to find a song.
    Basically, you hit the + key, type the number, then hit + again, and off it goes. I think I have it here if you're interested. I also have that plugin that drives an LCD character display and gives keypad control too.
    The ALEXIS Project
    Color Coding :
  1. Sony hu w/changer control input problem solved!
    By GMpc in forum General Hardware Discussion
    Last Post: 03-13-2009, 09:18 PM
  2. Pioneer AUX input problem
    By grunar in forum General Hardware Discussion
    Last Post: 12-02-2008, 03:43 AM
  3. input for panasonic deck
    By dizzytest in forum General MP3Car Discussion
    Last Post: 08-24-2007, 04:47 PM
  4. Can we get a forum devoted to input devices?
    By CA 3000GT in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-27-2003, 03:40 AM
  5. can I use an amplifier for rca input??
    By sheriff in forum General Hardware Discussion
    Last Post: 03-23-2001, 09:03 AM
