Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Powermate LED
  1. #11
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    BTW, I just found this alternative to PowerMate, called SpaceTraveller:
    http://www.3dconnexion.com/spacetraveler.htm
    Anyway its got blue illumination and appearently it has more then one LED only.
    On the other hand, IMHO it has much nicer look which will probably match our car interiors better then PowerMate.
    EDIT: ehmmm... I just realised it is a bit overpriced - it costs more then 650 Euro (yes, thats correct 650 Euro).
  2. #12
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    I have three of the powermates, two silver and one black. They all have blue LEDs in them. I tried getting one of them open, but didn't try real hard. At almost $45 a pop with shipping I didn't want to d*ck it up.
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  3. #13
    Newbie TheChiman's Avatar
    Mar 2005
    State College, PA
    I have looked online and I can find no evidence of there ever being a Limited Edition Black Powermate w/ red LED. I think I'm going to install the powermate in a recessed hole which would cover up the blue LED.
    LagunaICE, nice find. I like the extra buttons, however I'm not sure there are Mac OS drivers for the SpaceTraveler.
  4. #14
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    now that i look i cant find any evidence either, maybe i drempt it or something, or got confused with other people changing the leds too red??
    Signature: [==||========] 20% complete
  5. #15
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by BeaverWise
    As far as taking one apart, all you have to do is:
    1. Pull the top knob off & remove the circle of sponge
    2. Using a razor blade, carefully wedge it between the plastic bottom and the metal body. It's only glued on...
    3. On the top, remove the Lg nut.
    4. Push the shaft through the backside
    But you can't push it all the way out cause the wires are short...
    You also cannot pull the wire through the outside hole, the only way is to just cut it and re soldier it when done....the plastic strain releif prevents you from seperating the cord from the housing...
    Hope this helps...this was posted somewhere on here before but its easier to retype it than it will be to search for it....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. character led
    By MIG in forum General Hardware Discussion
    Last Post: 05-11-2003, 12:38 AM
  2. LCD to LED or LED meters.
    By silvertoy in forum LCD/Display
    Last Post: 02-17-2003, 11:07 PM
  3. Reset / HDD activity LED
    By JohnB1182 in forum General Hardware Discussion
    Last Post: 07-10-2002, 02:48 PM
  4. simple LED circuit.. did i do this right?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-04-2002, 12:23 AM
  5. Changing keypad LED lights!
    By brandondere in forum General Hardware Discussion
    Last Post: 04-11-2001, 10:13 AM
