Results 1 to 7 of 7
Thread: Using the Keyless Entry Remote
    Mar 2004
    I want my carputer to start up when I first unlock my car (it has an aftermarket alarm system complete with keyless entry) and then turn off when I lock it again after I am out of the car. I know this should be possible by modifying a shutdown controller, but was curious if anyone has tried this before. Any advice would be helpful, and I will share my experiences with anyone who is interested (it might be a few weeks before I can test anything out).
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    This is very simple to do. You just need to determine what kind of "pulse" gets sent to your door locks when you lock and unlock. Some use positive some send ground. After you have determined which it is in your case you just wire the outputs to a relay. Wire the relay to your motherboard with pin 30 going to 1 wire of the power switch and pin 87 to the other.Now when you hit unlock it will close the relay momentarily and "switch" the computer on and vice versa for lock.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    thats exactly what i did!
    Mar 2004
    That is basically what I planned on, you just forgot one important detail. What if I lock my doors while the car is going? I plan on using a modified shutdown controller or just designing my own that will have an override, so the computer will not turn off when the car is on. Thanks for the input.
    Nov 2003
    Here is an example of how you do it in a G35:
    http://g35driver.com/forums/showflat...=5&part=1&vc=1
    Quote Originally Posted by Sinorm
    Mar 2004
    Quote Originally Posted by Izik
    Thanks for the info, I plan on doing something very similar to that, but I will add an override so it can't turn off if the car is on.
    Mar 2004
    I designed a circuit to solve this problem without using relays. More importantly than the lack of relays, this circuit is capable of several things the circuit mentioned above.
    The post about it is here:
    http://www.mp3car.com/vbulletin/show...636#post185636
  1. Using Pioneer remote with PC (via Girder?)
    By bombboyer in forum Software & Software Development
    Last Post: 01-03-2005, 11:59 PM
  2. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  3. One remote to control them all
    By liquid_smoke in forum Input Devices
    Last Post: 01-22-2004, 10:00 AM
  4. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
  5. Great ir remote to control mp3car
    By rcpirate in forum General Hardware Discussion
    Last Post: 10-16-2002, 01:01 AM
