I have this remote, but stopped using it because it would not work after resuming from hibernate (software problem I'm sure).
I ended up buying a Keyspan USB remote. which is much better, comes with better software, and has an extremely sensitive receiver, no problems in bright light.
I know this isn't the answer you was looking for, but if you decide to ditch the CMR100, then you should check out the Keyspan.
LinkBack URL
About LinkBacks
