Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Has anyone hooked a webcam to their carputer? I searched but
  1. #21
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    yea an alarm....i see police running to every time a car alarm goes off. Plus locks keep honest people out. My car already has an alarm, installing audio and video security is just extra security. People freak when they ask about the cameras
  2. #22
    Variable Bitrate Banderon's Avatar
    Sep 2003
    NJ
    John, your site doesn't load. =\
    And agreed... standard car alarms are worthless. You need a police siren and some lights on there like me. =)
  3. #23
    Mar 2004
    Fort Myers, Fl
    oops, forgot to forward the port. site should work now. You got a P cruiser?
  4. #24
    FLAC Chairboy's Avatar
    Jan 2004
    Could you please answer the question about which software you use? I'm also interested.
    Thanks!
  5. #25
    Newbie screa_34's Avatar
    Mar 2004
    Burlingame, CA
    what software are you using to control the camera/recording. I am interesting in doing the same thing, but would like to have the camera on a loop so after 10 hours it would just start deleting the old recording as it added the new recording? Are you using any software that would do that?
  6. #26
    Mar 2004
    Fort Myers, Fl
    list of all software i am using.
    windows xp pro
    logitech drivers for both cams about $40 each.
    divx 5 drivers www.divx.com
    virtualdub to record from both cams www.virtualdub.org
    partition your hard drive into three drives C D and E
    Drive C can be any size partition you want.
    Drive D and E need to be 4gig but not bigger than 4.2gig.
    install virtualdub into two separate folders on Drive C.
    example c:\virtualdub1 c:\virtualdub2
    configure virtualdub1 to record to Drive D
    configure virtualdub2 to record to Drive E
    connect both usb cams and rename each one.
    example: cam1 cam2
    here are the virtualdub video and audio settings i am using.
    set both to these settings.
    audio settings- mp3 format at 56k
    video settings- divx5 compression at 250
    save settings and check both virtualdubs
    start virtualdub1 default avi file says d:\capture1.avi
    when you start virtualdub2 it will say the same thing change it to e:\capture1.avi
    make sure each one is using different cams
    click capture on virtualdub1 and virtualdub2.
    both should be recording at the same time audio and video
    stop both and check out your video clips
    now with these settings you can capture from both cams audio and video at the same time for about 1 week EACH CAM about 20 to 22fps.
    now reason why drives are 4gig.
    if something happens (someone breaks a window, someone backs into your car and the store), since to drive is 4gig, you can burn the entire 4gig clip to a dvdr (dvdr's hold 4.2gig)
    downside of this setup.
    you have to start and stop the recording manually. also you have to manually delete the file and if the video clip is bigger and 700meg you will need a dvdr burner to burn 4gig.
    this is how i am going to do it, i tested these settings and they do work.
    hardware epia 10000 with 512 memory
    20gig maxtor 7200rpm hard drive
    two logitech quick cam messengers
    pw-70
    now if someone knows how to make it auto start, stop, and delete or replace file, speak!!!!
    if you know of a better way, speak!!!!
    everyone wants to know, speak!!!! thats why i posted all this.
    enjoy
  7. #27
    Sep 2003
    NJ
    I'm sorry I'm too lazy to find this out on my own... but does VD work with command line commands? If so, you can make the necessary shortcut in your startup folder.
  8. #28
    Mar 2004
    Fort Myers, Fl
    dint thunk dat. seems possible.
  9. #29
    Mar 2004
    Fort Myers, Fl
    www.imyourgod.com ??? funny
  10. #30
    Jan 2004
    just curious ... but this would only help if someone tries to break into your car.. or steals something from passenger area... right??? (not for an instance of grand theft auto)
    its just like a thing to have evidence , or help find who broke in... .correct?
    u dont have wifi or anything that sends the video to an outside source correct?
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
  1. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 05:24 PM
  2. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
  3. Replies: 4
    Last Post: 02-16-2004, 09:08 AM
  4. Full carputer stereo replacement? Opinions Welcome.
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 12-26-2003, 11:42 PM
  5. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 10:10 AM
