Results 1 to 10 of 16
Thread: Pcmcia
    Jan 2004
    Pcmcia
    Hey guys,
    I have a troubling problem with a small form-factor computer I am working on. The computer has several USB ports, no serial, one mini-pci, no PCI ports. I need to connect a PCMCIA card to this compute somehow and I am having trouble figuring out how. I have looked all around for information about USB to PCMCIA adapters with little luck, do these even exist? Would it even work? Well, thanks for any advice or suggestions!
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Do you have a parallel port? I'm guessing that you are not using a printer in your car. If the parallel port is not going to be used for something else then you could do something with this:
    http://www.quatech.com/catalog/parallel_pcmcia.php
    Didn't shop around so there may be better prices elsewhere.
    ATVMS.com
    Low Bitrate frenchnew's Avatar
    Mar 2004
    Canada
    What specific type of PCMCIA device are you talking about?
    Depending on the device, there might be some options.
    Best regards
    frenchnew
    Quote Originally Posted by pbrinich
    Hey guys,
    Jan 2004
    Unfortunately there is no parallel either Only VGA, Stereo, USB, Ethernet and composite/S-video. I am trying to connect this FLASH-OFDM network card from flarion: http://www.flarion.com/products/over...t_Overview.pdf
    Feb 2004
    Omaha, NE
    I have done some searching on this as well and have yet to find a usb to pcmcia adapter that did something other than work as a card reader. Why not just get a usb network adapter like the Linksys WUSB11? Sell that pcmcia card on ebay or something. You can even get a different usb adapter that would allow you to use a different antenna and get even better range.
    ATVMS.com
    Jan 2004
    Well, the thing this PCMCIA card gets me is that it is for cell-based Wi-Fi internet access. I can use it anywhere in the Metropolitian area I live and give me about 1.5Mbps down and 750k up. I don't think even with some fancy antennas I could get that good coverage with 802.11, can I? Thanks for the reply!
    Feb 2004
    Omaha, NE
    If you get a good connection it would be faster. 802.11b is 11Mbps with a great connection and 802.11g is 54Mbps. Only problem is finding a network where with that card you would be always on regardless of location. And legal too.
    Edit: There is a charge associated with that connection isn't there? Take that into consideration as well if there is one.
    ATVMS.com
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by sfay93
    I think that works backwards from how you think it works.
    Feb 2004
    Omaha, NE
    Quote Originally Posted by none
    Yep, you are right. Looked at that too fast. The idea doesn't for him anyway because he doesn't have a parallel port.
    ATVMS.com
    FLAC Chairboy's Avatar
    Jan 2004
    http://www.elandigitalsystems.com/adapter/index.php
    PCI adapters to let you use PCMCIA cards in your PC. Whatever you have in your PCI slot, find a USB version of IT instead?
  1. Problem with connecting 2 Type II pcmcia cards to a Type III slot.
    By AVmobile in forum General Hardware Discussion
    Last Post: 01-28-2004, 10:14 PM
  2. PCMCIA or USB FM Stereo Card?
    By chut in forum General Hardware Discussion
    Last Post: 08-22-2003, 09:41 AM
  3. USB connected PCMCIA Slot?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-14-2003, 12:53 AM
  4. pcmcia card reader and pcmcia modem problem
    By dekodan in forum General Hardware Discussion
    Last Post: 05-24-2001, 01:04 AM
  5. Tell me what you think (+ looking 4 a pcmcia sound card)
    By bakassi in forum General Hardware Discussion
    Last Post: 04-05-2000, 07:17 PM
