Results 1 to 10 of 10
Thread: How I fixed my lilliput touchscreen problems
    Constant Bitrate gubon13's Avatar
    Los Angeles
    Post How I fixed my lilliput touchscreen problems
    Okay, I looked around and didn't see this posted yet. This pertains to the CY-4W-USB-03 touchscreen controller.
    I know that others are having the same problems that I was having. The touchscreen would cut in and out, and often times it would forget that it was a resistive screen in the touchkit utility. Hopefully this may help other people.
    I was so frustrated last night that I took out my screen and traced down all the wires for the USB and touchscreen. It turned out that the signal was not always going through to the USB from the touchscreen controller. On the controller was 4 wires - soldered directly onto the controller. It wasn't until I saw the EXACT SAME controller on www.digitalww.com that I realized there was supposed to be a pin connector, and not a direct wire solder.
    What I did was to desolder the wires from the controller, then solder in an RJ-11 (telephone) plug. It has the 4 wires that I need, and this allowed me to make my own cable. I chopped off the USB connector on the computer side, and just used it as a reference as to what pins were connected to which of the 4 wires on the controller.
    So now I have a cable with USB on the computer side, and an RJ-11 connector on the other side. (I'd like to say I chose this connector because it has the clip to hold it in place, or something else logical, but the fact is it was the only connector I had on hand.) Before testing it out, however, I had to remove the drivers and software and reboot. Then I reinstalled and rebooted again. Then after Windows (XP) came back up again, I plugged it in and installed the drivers for it. Now it works great and I have tried everything that would cause it to fail before, and it comes right up without a hitch every time. I did have to recalibrate it, as the calibration information was lost.
    I would like to add how utterly ****ED OFF I am that my screen was hacked together my someone who couldn't hold a straight soldering iron if his life depended on it...
    Anyhow, for those of you with similar problems and similarly soldered in wires, this may be worth a shot. Obviously the connector type doesn't matter, just that you make a new clean USB connection.
    Good luck to all, and I'll try to put up the wire color information when I get home.
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
    Maximum Bitrate none's Avatar
    Sep 2003
    Where did you get your screen? Put that ****ed-off energy to use and make sure nobody else buys from them.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I think that it is lilliput in general, not a particular supplier. Anyways....
    Thanks for the info. If i ever run accross that problem i will review this post....however i do have a couple of questions/comments...
    but fist i would like to say that i am glad that whatevery you did fixed your problem.
    the questions/comments...
    Usually a soldered connection is preferable to a connector as for signal continuity... why wouldn't this be the case with these new connection?
    Do you think that just re-soldering the conections properly would have fixed it?
    Also, do you think that it was the fabrication of the new cable was the thing that fixed your problem?
    Anyhow Great Post, some pictures and pinouts would be an awesome adition.
    Cheers
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Quote Originally Posted by none
    I think we have been here before. A lilliput is a lilliput is a lilliput. No matter who sells them, they are made by lilliput. Saying a seller is bad becasue he sold a lilliput wont help. I am peeved that I bought a lilly from Hong Kong, but it isnt their fault it broke, it is lilliputs fault for poorly building, and re-using screens and such that isnt really a good business practice. I cant hold the seller liable.
    2005 Ford Focus ST
    Los Angeles
    Agreed - I purposedly did not include the seller's name because it is lilliput that manufactured it poorly.
    As for the soldering question - I chose not to resolder on the wires because it was BOTH the cable and the soldered connection. The cable when plugged in would not get continuity from the controller solder points to the pins on the other end. Even from the black multi-pin connector to the usb cable it was not getting a solid connection - it would cut in and out.
    Also, the reason that I put a new connector on the touchscreen controller, rather than just soldering in a new usb cable was because it would have been difficult to get it in and out of my dash with it connected and running under the carpet. As it is now, I can just disconnect the power, vga, and touchscreen and it's out of there. I would have prefered the continuity of a direct solder, but this was not a good option for me.
    Will get the pinouts up later. Unfortunately, I don't have a camera, so can't take any photos, at least not until I can borrow one.
    Sep 2003
    Oops I didn't realize when I wrote that he was talking about a Lilliput (despite that info staring me in the face. ) The issue about seeing the same controller elsewhere threw me off and got me thinking he was talking about a cobbled together unit.
    Jun 2003
    Memphis - TN
    We shoud get a class action suit
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Los Angeles
    Here's the pinout for the touchscreen controller and the usb cable. Just in case anyone wants to make their own cable.
    Aug 2003
    Orange, NJ
    Anyone has the pinout for the VGA cable?
    2002 Chevrolet Avalanche
    Zotac NForce 610i ITX, 2GB RAM, 2.6 GHz Intel Pentium Dual Core CPU, 320 GB Hard Drive, 12' VGA touchscreen monitor, 3D mouse
    My Worklog : http://www.mp3car.com/vbulletin/work...avalanche.html
    Variable Bitrate wkolodny's Avatar
    DC
    see this thread
    Quote Originally Posted by Dluvr22
    Hard wire the Lilliput DIN connector6[/URL]
    Don't Fear The Gurkey
    Click here to check out My Setup
  1. No Signal on Lilliput 7 Inch touchscreen.
    By SuperDave01 in forum LCD/Display
    Last Post: 05-04-2008, 10:36 AM
  2. Lilliput Touchscreen Problems
    By MWCARPC in forum LCD/Display
    Last Post: 04-21-2004, 05:33 PM
  3. Replies: 1
    Last Post: 04-11-2004, 09:12 AM
  4. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
  5. lilliput touchscreen problems
    By dominic in forum Input Devices
    Last Post: 01-14-2004, 07:50 PM
