Yep. Lower resistors. Change both 10K to 1K and see if that works. You should get most, if not all the buttons then. That's more like what god shows in the original diagram. He also went down to 500 ohms, but that seems like it may be too much drain when it's taking 5V to ground through 500 + 52 + 500 ohms. Here's a little more info on mine (I'm working with higher resistances):
1.3K = Volume up
1.6K = Volume down
1.9K = Play
2.4K = Mute
3.1K = Seek up
4.3K = Seek down
6.7K = AM/FM
13.6K = Preset
If I change both resistors to 1K then volume up / volume down / play work and are really stable, and if I change the 5V->axis one to 15K (and leave the other at 10K) then seek up / seek down / amfm / preset works. It's confusing to say the least. The radioshack adaptor is probably just designed bad or something.
LinkBack URL
About LinkBacks
